Simplification VBA
Je dispose d'un code VBA qui fonctionne mais je pense qu'il peut être simplifier surtout au niveau des RAZ des som , j'ai essayé avec:
For i=1 to 18
som(i)=0
Mais ça ne fonctionne pas. Voici le code intégral:
Sub SommeReportingQE()
Dim Nlgn As Integer
Dim tabBDD()
Dim wsBDD As Object
Dim wsResult As Object
Dim som1, som2, som3, som4, som5, som6, som7, som8, som9, som10, som11, som12, som13, som14, som15, som16, som17, som18
Dim crit1, crit2, crit3, crit4
Dim cptBDD
Dim i As Integer
Nlgn = ActiveCell.Column
    Set wsBDD = Worksheets("BDD")
    Set wsResult = Worksheets("Feuil1")
    With wsBDD
        tabBDD = Range(.Cells(3, 1), .Cells(.Cells(Rows.Count, 1).End(xlUp).Row, 23))
    With wsResult
    som1 = 0
    som2 = 0
    som3 = 0
    som4 = 0
    som5 = 0
    som6 = 0
    som7 = 0
    som8 = 0
    som9 = 0
    som10 = 0
    som11 = 0
    som12 = 0
    som13 = 0
    som14 = 0
    som15 = 0
    som16 = 0
    som17 = 0
    som18 = 0
        crit1 = .Cells(2, 1)
        crit2 = .Cells(1, Nlgn)
        crit3 = .Cells(8, 1)
        crit4 = .Cells(14, 1)
        For cptBDD = 1 To UBound(tabBDD, 1)
            If (tabBDD(cptBDD, 23) = crit1) And (tabBDD(cptBDD, 1) = crit2) Then
                som1 = som1 + tabBDD(cptBDD, 11)
                som2 = som2 + tabBDD(cptBDD, 22)
                som3 = som3 + tabBDD(cptBDD, 12)
                som4 = som4 + tabBDD(cptBDD, 14) + tabBDD(cptBDD, 15) + tabBDD(cptBDD, 16) + tabBDD(cptBDD, 18) + tabBDD(cptBDD, 20)
                som5 = som5 + tabBDD(cptBDD, 19)
                som6 = som6 + tabBDD(cptBDD, 17)
            If (tabBDD(cptBDD, 23) = crit3) And (tabBDD(cptBDD, 1) = crit2) Then
                som7 = som7 + tabBDD(cptBDD, 11)
                som8 = som8 + tabBDD(cptBDD, 22)
                som9 = som9 + tabBDD(cptBDD, 12)
                som10 = som10 + tabBDD(cptBDD, 14) + tabBDD(cptBDD, 15) + tabBDD(cptBDD, 16) + tabBDD(cptBDD, 18) + tabBDD(cptBDD, 20)
                som11 = som11 + tabBDD(cptBDD, 19)
                som12 = som12 + tabBDD(cptBDD, 17)
            If (tabBDD(cptBDD, 23) = crit4) And (tabBDD(cptBDD, 1) = crit2) Then
                som13 = som13 + tabBDD(cptBDD, 11)
                som14 = som14 + tabBDD(cptBDD, 22)
                som15 = som15 + tabBDD(cptBDD, 12)
                som16 = som16 + tabBDD(cptBDD, 14) + tabBDD(cptBDD, 15) + tabBDD(cptBDD, 16) + tabBDD(cptBDD, 18) + tabBDD(cptBDD, 20)
                som17 = som17 + tabBDD(cptBDD, 19)
                som18 = som18 + tabBDD(cptBDD, 17)
        .Cells(2, Nlgn) = som1
        .Cells(3, Nlgn) = som2
        .Cells(4, Nlgn) = (.Cells(3, Nlgn) / som3)
        .Cells(5, Nlgn) = som4
        .Cells(6, Nlgn) = som5
        .Cells(7, Nlgn) = som6
        .Cells(8, Nlgn) = som7
        .Cells(9, Nlgn) = som8
        .Cells(10, Nlgn) = (.Cells(9, Nlgn) / som9)
        .Cells(11, Nlgn) = som10
        .Cells(12, Nlgn) = som11
        .Cells(13, Nlgn) = som12
        .Cells(14, Nlgn) = som13
        .Cells(15, Nlgn) = som14
        .Cells(16, Nlgn) = (.Cells(15, Nlgn) / som15)
        .Cells(17, Nlgn) = som16
        .Cells(18, Nlgn) = som17
        .Cells(19, Nlgn) = som18
    Set wsBDD = Nothing
    Set wsResult = Nothing
en utilisant un tableau pour tes variables som on peut un peu simplifier le code (écriture) pas nécessairement son exécution.
    Dim Nlgn As Integer
    Dim tabBDD()
    Dim wsBDD As Object
    Dim som(1 To 18)
    Dim cptBDD
    Dim i As Integer
    With wsBDD
    With wsResult
        Erase som
                som(1) = som(1) + tabBDD(cptBDD, 11)
                som(2) = som(2) + tabBDD(cptBDD, 22)
                som(3) = som(3) + tabBDD(cptBDD, 12)
                som(4) = som(4) + tabBDD(cptBDD, 14) + tabBDD(cptBDD, 15) + tabBDD(cptBDD, 16) + tabBDD(cptBDD, 18) + tabBDD(cptBDD, 20)
                som(5) = som(5) + tabBDD(cptBDD, 19)
                som(6) = som(6) + tabBDD(cptBDD, 17)
                som(7) = som(7) + tabBDD(cptBDD, 11)
                som(8) = som(8) + tabBDD(cptBDD, 22)
                som(9) = som(9) + tabBDD(cptBDD, 12)
                som(10) = som(10) + tabBDD(cptBDD, 14) + tabBDD(cptBDD, 15) + tabBDD(cptBDD, 16) + tabBDD(cptBDD, 18) + tabBDD(cptBDD, 20)
                som(11) = som(11) + tabBDD(cptBDD, 19)
                som(12) = som(12) + tabBDD(cptBDD, 17)
                som(13) = som(13) + tabBDD(cptBDD, 11)
                som(14) = som(14) + tabBDD(cptBDD, 22)
                som(15) = som(15) + tabBDD(cptBDD, 12)
                som(16) = som(16) + tabBDD(cptBDD, 14) + tabBDD(cptBDD, 15) + tabBDD(cptBDD, 16) + tabBDD(cptBDD, 18) + tabBDD(cptBDD, 20)
                som(17) = som(17) + tabBDD(cptBDD, 19)
                som(18) = som(18) + tabBDD(cptBDD, 17)
        For i = 1 To 18
            Select Case i
            Case 3, 9, 15
                .Cells(i + 1, Nlgn) = (.Cells(i, Nlgn) / som(i))
            Case Else
                .Cells(i + 1, Nlgn) = som(i)
            End Select
    Set wsBDD = Nothing
Salut Florian, H2SO4
Bonjour le forum,
A tester puisqu'on travaille un peu à l'aveugle, sans fichier !!
Dim wsBDD As Worksheet
Dim wsResult As Worksheet
Dim tabBDD()
Dim Som(19) As Integer, iCol As Integer
iCol = ActiveCell.Column
With wsBDD
With wsResult
    crit2 = .Cells(1, iCol)
    For y = 1 To UBound(tabBDD, 1)
        Select Case tabBDD(y, 23) + tabBDD(y, 1)
            Case Is = (crit1 + crit2)
                x = 0
            Case Is = (crit3 + crit2)
                x = 1
            Case Is = (crit4 + crit2)
                x = 2
        End Select
        Som(1 + (x * 6)) = Som(1 + (x * 6)) + tabBDD(y, 11)
        Som(2 + (x * 6)) = Som(2 + (x * 6)) + tabBDD(y, 22)
        Som(3 + (x * 6)) = Som(3 + (x * 6)) + tabBDD(y, 12)
        Som(4 + (x * 6)) = Som(4 + (x * 6)) + tabBDD(y, 14) + tabBDD(y, 15) + tabBDD(y, 16) + tabBDD(y, 18) + tabBDD(y, 20)
        Som(5 + (x * 6)) = Som(5 + (x * 6)) + tabBDD(y, 19)
        Som(6 + (x * 6)) = Som(6 + (x * 6)) + tabBDD(y, 17)
    For x = 1 To 18
        Select Case x
            Case 4, 10, 16
                .Cells(x + 1, iCol) = (.Cells(x, iCol) / Som(x))
            Case Else
                .Cells(x + 1, iCol) = Som(x)
        End Select
Set wsBDD = Nothing
Pas mal la simplification .
merci à vous, je n'en reviens pas de ta simplification curulis57 , elle est juste énorme. je vais la tester et je vous redis .
Florian,
ne te trompe pas de version : je l'ai changée deux fois en édition directe!
Quand c'est chaud, c'est chaud!
J'ai essayé le code, j'ai une erreur "indice n'appartient pas à la selection " sur la ligne:
Select Case tabBDD(cptBDD, 23) + tabBDD(cptBDD, 1)
Je ne vois pas de déclaration pour "cptBDD" est ce pour ça que j'ai une erreur ?
Dsl je viens de voir ton message, du coup j'essaye la nouvelle version
Après essai, en fait ma première macro, insérer les formules de la colonne C à "dercol".
Quand j'ai utilisé ta macro, icol avait pour valeur "activecell.collumn".
J'ai fais une modif :
Sub SommeASS()
Dim tabBDD()
Dim Som(19) As Long, iCol As Integer
Set wsResult = Worksheets("ASS Costs")
With wsBDD
With wsResult
dercol = Cells(1, Cells.Columns.Count).End(xlToLeft).Column
For iCol = 3 To dercol
    crit3 = .Cells(9, 1)
    crit4 = .Cells(15, 1)
                x = 0
                x = 1
                x = 2
        End Select
   For x = 1 To 18
        Select Case x
            Case 4, 10, 16
            Case Else
        End Select
    Next iCol
Set wsBDD = Nothing
Sa ne fonctionne toujours pas je pense qu'il y a une erreur avec "Som(1 + (x * 6)" car je me retrouve a avoir x=10 quand la macro bloque, je ne comprends pas à quel moment elle peut prendre cette valeur.
29simplification.xlsx (14.82 Ko)
Florian,
comment veux-tu que nous comprenions ? Le fichier n'est pas complet !
Le code fait référence à des feuilles que l'on ne peut pas voir!
Une description sommaire de ce que tu veux faire nous aiderait aussi!
Voici un exemple, qui je l’espère sera plus détaillé
Ton code fonctionne bien, mais il ne s'applique seulement à la colonne active, alors que je voudrais du'il s'applique de la colonne "C" à dernière colonne rempli en fonction de la ligne "1"
21simplification.xlsx (19.42 Ko)
Salut Florian,
Je navigue toujours à vue... les feuilles que tu m'as fournies sont quasi vides d'info que l'on ne peut deviner!
Il fonctionne ? Etonnant !
Je remarque que tu testes tabBDD(y, 23) alors que ce tableau ne compte que 21 colonnes!
J'ai nommé ta feuille de résultats 'ASS Costs'.
Tes critères (crit1-4) : certains sont numériques et le 2 est alphanumérique si j'ai bien vu. Je teste donc une concaténation ( & ) des critères plutôt qu'une addition, forcément.
J'allais oublier : dans le code ci-dessous, la partie originale d'affectation des Som() est en commentaire avec tes valeurs.
La partie effective, si tu regardes bien, n'a pas les mêmes indices. J'ai réduit chacun de 2 ce qui correspond à l'erreur de 2 indices de ton tableau tabBDD. Vérifie deux fois plutôt qu'une!
A tester! Je n'ai pas la matière pour le faire!
Sub SommeASS()
Dim sWkBDD As Worksheet
Dim sWkASS As Worksheet
Dim tabBDD()
Set sWkBDD = Worksheets("BDD")
Set sWkASS = Worksheets("ASS Costs")
With sWkBDD
    iRow = Range("B" & Rows.Count).End(xlUp).Row
    tabBDD = .Range("B3:V" & iRow).Value
With sWkASS
    crit1 = .Cells(2, 1) ' Electrical cook
    crit3 = .Cells(9, 1) 'Beverage
    crit4 = .Cells(15, 1) 'Food preparation
    For iCol = 3 To .Cells(1, Columns.Count).End(xlToLeft).Column
        crit2 = .Cells(1, iCol) ' Period
            Select Case tabBDD(y, 1) & tabBDD(y, 21)
                Case Is = crit2 & crit1
                    x = 0
                Case Is = crit2 & crit3
                    x = 1
                Case Is = crit2 & crit4
                    x = 2
            End Select
            Som(1 + (x * 6)) = Som(1 + (x * 6)) + tabBDD(y, 9)
            Som(2 + (x * 6)) = Som(2 + (x * 6)) + tabBDD(y, 20)
            Som(3 + (x * 6)) = Som(3 + (x * 6)) + tabBDD(y, 10)
            Som(4 + (x * 6)) = Som(4 + (x * 6)) + tabBDD(y, 12) + tabBDD(y, 13) + tabBDD(y, 14) + tabBDD(y, 16) + tabBDD(y, 18)
            Som(5 + (x * 6)) = Som(5 + (x * 6)) + tabBDD(y, 17)
            Som(6 + (x * 6)) = Som(6 + (x * 6)) + tabBDD(y, 15)
            'Som(1 + (x * 6)) = Som(1 + (x * 6)) + tabBDD(y, 11)
            'Som(2 + (x * 6)) = Som(2 + (x * 6)) + tabBDD(y, 22)
            'Som(3 + (x * 6)) = Som(3 + (x * 6)) + tabBDD(y, 12)
            'Som(4 + (x * 6)) = Som(4 + (x * 6)) + tabBDD(y, 14) + tabBDD(y, 15) + tabBDD(y, 16) + tabBDD(y, 18) + tabBDD(y, 20)
            'Som(5 + (x * 6)) = Som(5 + (x * 6)) + tabBDD(y, 19)
            'Som(6 + (x * 6)) = Som(6 + (x * 6)) + tabBDD(y, 17)
        For x = 1 To 18
            Select Case x
                Case 4, 10, 16
                    .Cells(x + 1, iCol) = .Cells(x, iCol) / Som(x)
                Case Else
            End Select
Set sWkBDD = Nothing
Set sWkASS = Nothing
Encore une chose : applique-toi dans l'indentation de ton code! Tu te reliras toi-même plus facilement.
Merci à toi de prendre du temps afin de m'aider,
Dans mon tableau "BDD" les valeurs sont jusqu'à la colonne "W" donc c'est bien la colonne 23, si je me trompe pas .
Pour ce qui est des critères , comme dans premier exemple je ne m'occupe pas des numériques ou alphanumérique, je les compare si elles sont identiques elles réponds au critères sinon, non.
Je croyais que ma 1er macro fonctionnait de la colonne "C" à dercol mais non en fait, je me suis trompé.
Par contre son fonctionnement est bon, les résultat sont correct sauf, qu'il faudrait quelle s'applique jusqu'à "dercol".
Je dispose d'une macro qui me remplie la ligne 1 avec choix dynamique, je peux avoir 4 à 10 choix dans la ligne1 de la Feuil1. Et apès je voudrais que s’exécute la macro en question .
Salut Florian,
reste en ligne qu'on puisse avancer!
Qu'est-ce qui est bon dans ma macro, finalement?
Avec des tableaux à moitié remplis, je navigue dans le brouillard...
En fait quand je compare la tienne et la mienne les résultats ne sont pas les mêmes, et ta macro plante avec "Dépassement de capacité" à la ligne 11. Les résultats obtenus de la ligne 2 à 10 ne sont pas bons.
J'ai corrigé certaines choses... mais encore une fois, j'ai besoin de voir pour comprendre!
A vue, avec des tableaux à moitié vides, sans savoir de quoi il retourne, parfois, la logique ne suffit pas...
Sub SommeASS()
Dim tabBDD()
Dim Som(19) As Double, iCol As Integer
With sWkBDD
    iRow = Range("A" & Rows.Count).End(xlUp).Row
    tabBDD = .Range("A3:W" & iRow).Value
With sWkASS
            Select Case tabBDD(y, 1) & tabBDD(y, 23)
                    iIdx = 0
                    iIdx = 1
                    iIdx = 2
            End Select
            Som(1 + (iIdx * 6)) = Som(1 + (iIdx * 6)) + tabBDD(y, 11)
            Som(2 + (iIdx * 6)) = Som(2 + (iIdx * 6)) + tabBDD(y, 22)
            Som(3 + (iIdx * 6)) = Som(3 + (iIdx * 6)) + tabBDD(y, 12)
            Som(4 + (iIdx * 6)) = Som(4 + (iIdx * 6)) + tabBDD(y, 14) + tabBDD(y, 15) + tabBDD(y, 16) + tabBDD(y, 18) + tabBDD(y, 20)
            Som(5 + (iIdx * 6)) = Som(5 + (iIdx * 6)) + tabBDD(y, 19)
            Som(6 + (iIdx * 6)) = Som(6 + (iIdx * 6)) + tabBDD(y, 17)
        For x = 1 To 18
            Select Case x
                Case 4, 10, 16
                    If Som(x) > 0 Then .Cells(x + 1, iCol) = .Cells(x, iCol) / Som(x)
                Case Else
            End Select
    .Columns("A:M").AutoFit
J'ai remis ton tableau à 23 indices. C'est toi qui avait raison sur ce coup-là!
J'ai des Som() à zéro d'où dépassement de capacité car division par zéro.
Merci à toi , les valeurs ne correspondent toujours pas. je mets en pièce jointe un fichier plus rempli si vous voulez mieux comprendre
Il n'y a pas de fichier, Florian!
Je viens de faire ce code qui fonctionne sur toutes les colonnes mais pas très simplifié
Dim Nlgn As Integer
Dim tabBDD()
Dim wsBDD As Object
Dim cptBDD
Dim i As Integer
dercol = Cells(1, Cells.Columns.Count).End(xlToLeft).Offset(0, 0).Column
For Nlgn = 3 To dercol
    With wsBDD
    With wsResult
    som1 = 0
    som2 = 0
    som3 = 0
    som4 = 0
    som5 = 0
    som6 = 0
    som7 = 0
    som8 = 0
    som9 = 0
    som10 = 0
    som11 = 0
    som12 = 0
    som13 = 0
    som14 = 0
    som15 = 0
    som16 = 0
    som17 = 0
    som18 = 0
    Set wsBDD = Nothing
    Next Nlgn
Eh bien, on n'est pas sorti de l'auberge!
Ton fichier est inutilisable et le code que tu m'as envoyé recèle les mêmes erreurs que le mien... forcément avec des tableaux vides!
Envoie-moi ton "vrai" fichier à l'adresse mail que je t'ai laissée en message privé, stp!
Rechercher des sujets similaires à "simplification vba"
