Salut Forum!
Après quelques heures passées sur mon script pour envoyer un mail depuis mon userform tout fonctionne très bien
Seul hic ma signature ne s'affiche pas mais plutot un gros X rouge que outlook bloque probablement ...
Quelqu'un aurait une idée?
Private Sub CommandButton117_Click()
Dim SigString As String
Dim Signature As String
SigString = Environ("appdata") & _
"\Microsoft\Signatures\CRFLIX.htm"
If Dir(SigString) <> "" Then
Signature = GetBoiler(SigString)
Signature = ""
On Error Resume Next
Dim OutApp As Outlook.Application
Dim lItem As Long
For lItem = 0 To ListBox1.ListCount - 1
If ListBox2.Selected(lItem) = True Then
Sheets("Clients").Range("DD65536").End(xlUp)(2, 1) = ListBox2.List(lItem)
ListBox2.Selected(lItem) = False
Sheets("Clients").Select
'--- Envoi par mail
Dim olapp As Outlook.Application
Set OutApp = CreateObject("Outlook.Application")
Range("DD2").Select
Do While Not IsEmpty(ActiveCell)
Dim msg As MailItem
Set olapp = New Outlook.Application
Set msg = olapp.CreateItem(olMailItem)
msg.To = ActiveCell.Value
msg.Subject = Me.TextBox16.Value
msg.HTMLBody = "<p>" & Me.TextBox17.Value & "</p>" & Signature
msg.Attachments.Add Source:=Me.filenameinput.Value
msg.SendUsingAccount = OutApp.Session.Accounts.Item(1)
msg.Send
ActiveCell.Offset(1, 0).Select
Loop
' On Error GoTo 0
' Set OutMail = Nothing
' Set OutApp = Nothing
'End Sub
Function GetBoiler(ByVal sFile As String) As String
'Dick Kusleika
Dim fso As Object
Dim ts As Object
Set fso = CreateObject("Scripting.FileSystemObject")
Set ts = fso.GetFile(sFile).OpenAsTextStream(1, -2)
GetBoiler = ts.ReadAll
ts.Close
End Function
