Voila une macro Import Txt
Private Sub ChoixFicTxt()
Dim dossier As FileDialog
ChoixChemin = ActiveWorkbook.Path & Application.PathSeparator
Set dossier = Application.FileDialog(msoFileDialogFilePicker)
With dossier
.AllowMultiSelect = False
.InitialFileName = ChoixChemin
.Title = "Choix d'un fichier Txt"
.Filters.Clear
.Filters.Add "Fichier Txt ", "*.txt*", 1
If .Show = -1 Then
Chemin = .SelectedItems(1)
LireMan Chemin
Set dossier = Nothing
Sub LireMan(NomFichier)
Dim Ar() As String
Dim Lig&, Col&, X&
With Application
.ScreenUpdating = False
.EnableEvents = False
.Calculation = xlManual
Rows("1:" & Rows.Count).ClearContents
'Sep = ","
Sep = vbTab
Lig = 1
On Error Resume Next
Open NomFichier For Input As #1
Do While Not EOF(1)
Line Input #1, Chaine
Ar = Split(Chaine, Sep)
Col = 1
For X = LBound(Ar) To UBound(Ar)
Select Case Col
Case 3, 13
Cells(Lig, Col).Value = CDate(Ar(X))
Case 6
Cells(Lig, Col).Value = CDbl(Ar(X))
Case Else
Cells(Lig, Col).Value = CStr(Ar(X))
End Select
Col = Col + 1
Lig = Lig + 1
Loop
Close #1
With Application
.ScreenUpdating = True
.Calculation = xlCalculationAutomatic
.EnableEvents = True
.CutCopyMode = False
.Goto [A1], True
Maurice
