re rosa14
A tester avec le fichier de ton premier post.
On est d'accord, pas de chevauchement de dates et les données sont triées par ordre chronologique
Sub test()
Dim a, e, w(), i As Long, ii As Long, n As Long, nbreJ As Long, dico As Object
Set dico = CreateObject("Scripting.Dictionary")
dico.CompareMode = 1
a = Sheets("Absences").Cells(1).CurrentRegion.Value2
For i = 2 To UBound(a, 1)
If Not dico.exists(a(i, 1)) Then
ReDim w(1 To 6, 1 To 1)
For ii = 1 To UBound(a, 2) - 1
w(ii, 1) = a(i, ii)
w = dico(a(i, 1))
If a(i, 2) = w(UBound(w, 1) - 3, UBound(w, 2)) + 1 Then
w(UBound(w, 1) - 3, UBound(w, 2)) = a(i, 3)
ReDim Preserve w(1 To UBound(w, 1), 1 To UBound(w, 2) + 1)
w(ii, UBound(w, 2)) = a(i, ii)
dico(a(i, 1)) = w
For Each e In dico.keys
w = dico.Item(e)
For i = 1 To UBound(w, 2)
nbreJ = w(3, i) - w(2, i) + 1
Select Case nbreJ
Case Is > 30: w(6, i) = nbreJ
Case Is > 3: w(5, i) = nbreJ
Case Else: w(4, i) = nbreJ
End Select
dico.Item(e) = w
With Sheets.Add
.Cells(1).Resize(, 6).Value = _
Array("N° Employé", "Date de début Paye", "Date de fin Paye", _
"jours " & ChrW(8804) & " 3", "3 < jours " & ChrW(8804) & " 30", "jours > 30")
n = 2
With .Cells(n, 1).Resize(UBound(dico.Item(e), 2), UBound(dico.Item(e), 1))
.Value = Application.Transpose(dico.Item(e))
.BorderAround Weight:=xlThin
n = n + UBound(dico.Item(e), 2)
With .Cells(1).CurrentRegion
.Font.Name = "calibri"
.Font.Size = 10
.VerticalAlignment = xlCenter
.Borders(xlInsideVertical).Weight = xlThin
With .Rows(1)
.Font.Size = 11
.Interior.Color = 9359529
.Columns(2).NumberFormat = "m/d/yyyy"
.Columns(3).NumberFormat = "m/d/yyyy"
.Columns.ColumnWidth = 18
Set dico = Nothing
klin89
