Probleme macro enregistrée
Bonjours a tous,
j ai enregistré cette macro avec l enregistreur et je ne comprends pas pourquoi le resultat donnne #NOM? Si apres je retourne sur la cellule et je valide la formule avec "enter" alors #NOM? disparait et le calcul s effecture correctement (sans rien toucher du tout a la formule)
Je deja fais la manip avec plusieurs autres formules du meme type sans probleme, mais avec celle la, pas moyen !!
je joins un fichier
Flo
14macro-cu.xlsm (26.09 Ko)
Un essai ...
Sub CUPIE()
   ' CUPIE Macro
   Range("CU46").FormulaR1C1 = _
   "=IF(OR(LEN(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(RC[-85],""B"",""""),""R"",""""),""T"",""""),""N"",""""),""M"",""""),""O"",""""),""V"",""""),""W"",""""),""G"",""""))>0,LEN(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(RC[-84],""B"",""""),""R"",""""),""T" & _
                               """,""""),""N"",""""),""M"",""""),""O"",""""),""V"",""""),""W"",""""),""G"",""""))>0,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""B"",""""))+LEN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""B"",""""))>2,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""B"",""""))>1,LEN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""B"",""""))>1,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""R"",""""))+LEN(RC[-84])-LEN(SUBSTITUTE(RC[-8" & _
                               "4],""R"",""""))>2,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""T"",""""))+LEN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""T"",""""))>2,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""N"",""""))+LEN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""N"",""""))>1,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""M"",""""))+LEN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""M"",""""))>2,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""O"",""""))+L" & _
                               "EN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""O"",""""))>2,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""W"",""""))+LEN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""W"",""""))>2,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""G"",""""))+LEN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""G"",""""))>1,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""V"",""""))+LEN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""V"",""""))>1),1,0)" & ""
   Range("CU46").Select
   Selection.AutoFill Destination:=Range("CU46:CU138")
ric
Le code corrigé
Sub CUPIE()
"EN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""O"",""""))>2,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""W"",""""))+LEN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""W"",""""))>2,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""G"",""""))+LEN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""G"",""""))>1,LEN(RC[-85])-LEN(SUBSTITUTE(RC[-85],""V"",""""))+LEN(RC[-84])-LEN(SUBSTITUTE(RC[-84],""V"",""""))>1),1,0)" & _
Range("CU46").AutoFill Destination:=Range("CU46:CU138")
PS : n'oubliez pas de cloturer le fil si ok
super, merci a vous 2, ca marche impec, je me souviendrais de FormulaR1C1 la prochaine fois.
Par contre une question de novice...Pourquoi lors de l enregistrement automatique de macro, pour les tres longues formules, lorsque l editeur VBA retourne a la ligne avec "& _ " alors quand j ouvre le code par la suite, il manque toujours des bouts de formules apres les sauts de lignes ? il manque toujours 4 ou 5 caracteres. Ca vient d un parametre a changer dans l editeur ?
Merci bonne fin de journee a tous
Rechercher des sujets similaires à "probleme macro enregistree"
