Open Excel macro without running
Hi;
Please I need your help ;
I create an an axcel macro that works correctly; but , when I add this code to my macro in "PERSO.XLS" from the start directory of MS Excel ( in a bad place in the macro);I can't open the macro , and , I can't find it.. Pleeaaaase help ; how can I Open the macro to delete this bad code !!!
Dim sKill As String
sKill ="TASKKILL /f /IM EXCEL.EXE" ....
shell sKill , vbHide
Hello
I do not know if it works, but try
Search your computer for the file "Personal.xls", renamed it and works it like any Excel file
Je ne sais pas si cela fonctionne, mais il faut essayer
Recherches dans ton ordinateur le fichier "Perso.xls", renommes-le puis ouvres le comme n'importe quel fichier Excel
Edit
Hello
alternative
When opening Excel
In the Windows menu ---> Show
choose Personal
Then you have access to your file "Personal.xls"
Autre solution
A l'ouverture d'Excel
Dans le menu Fenêtres ---> Afficher
Choisir Perso
Ensuite tu as accès à ton fichier "Perso.xls"
Rechercher des sujets similaires à "open macro without running"
