Next without For
Hi
I am trying to create a VBA to clear a list with specific works.
I am having this issue:
Next without For.
Anybody could help me.
Thanks
Sub Macro1()
' Macro1 Macro
Dim a As Integer
'keyword.
Sheets("List Material to Deleted").Select
For a = 1 To 100
Text = Cells(a, 1)
If Text = "" Then Exit Sub
Cells(a, 2).FormulaR1C1 = "=LEN(RC[-1])"
LONGITUD = Cells(a, 2).FormulaR1C1 = "=LEN(RC[-1])"
'search to delete.
Sheets("ML").Select
Dim b As Integer
For b = 1 To 300
text2 = Cells(b, 1)
If text2 = "" Then Exit Sub Else
If (Left(Cells(b, 1), LONGITUD) = Text) Then
Cells(b, 1).ClearContents
Next b
Next a
Tu as simplement inversé l'ordre du "End If" et du "Next".
   For b = 1 To 300
      text2 = Cells(b, 1)
      End If      ' << ici
   Next b      ' << et ici
ric
Merci!
Rechercher des sujets similaires à "next without"
