If cellule vide goto
Y
Bonjour l'équipe,
j'ai essayé d'écrire un code mais ile ne marche pas je suis aujourd'hui là pour sollicité votre aide :
ici ce qui marche pas c'est : If range("AR4" & "AS4").value = "" go to line1
merci d'avance j'espère que j'étais clair
'gjn
Range("AU4").Value = Range("AR4").Value - Range("D4").Value
'vbn
Range("AV4").Value = Range("AS4").Value - Range("E4").Value
For U = 9 To 40
Cells(U, 9) = Cells(U, 9) + Range("AU4").Value
Cells(U, 13) = Cells(U, 13) + Range("AU4").Value
Cells(U, 17) = Cells(U, 17) + Range("AU4").Value
Cells(U, 10) = Cells(U, 10) + Range("AV4").Value
Cells(U, 14) = Cells(U, 14) + Range("AV4").Value
Cells(U, 18) = Cells(U, 18) + Range("AV4").Value
Next U
Range("D4").Value = Range("AR4").Value
Range("E4").Value = Range("AS4").Value
'REMA
For h = 9 To 40
If Cells(h, 24) = "N/A" Then
Cells(h, 24) = Cells(h, 24) - Feuil5.Range("AU4").Value
Next h
'REM
For E = 9 To 40
If Cells(E, 24) = "N/A" Then
Cells(E, 24) = Cells(E, 24) - Feuil5.Range("AV4").Value
Next E
line 1 :
'WFG
Feuil14.Range("O2:U2").ClearContents
Feuil5.Range("G4:Z4").ClearContents
Dim Compid As Range
Set Compid = Feuil14.Range("A:A").Find(what:=Range("B4").Value, LookIn:=xlValues, lookat:=xlWhole)
Feuil14.Range("O2").Value = Compid.Offset(, 1).Value
Feuil14.Range("P2").Value = Compid.Offset(, 2).Value
Feuil14.Range("Q2").Value = Compid.Offset(, 3).Value
Feuil14.Range("R2").Value = Compid.Offset(, 10).Value
Feuil14.Range("S2").Value = Compid.Offset(, 11).Value
Feuil14.Range("T2").Value = Compid.Offset(, 12).Value
Feuil14.Range("U2").Value = Compid.Offset(, 9).Value
Feuil5.Range("G4").Value = Feuil14.Range("O2")
Feuil5.Range("H4").Value = Feuil14.Range("U2")
'LES
Feuil14.Range("N2:N15").ClearContents
Feuil5.Range("Z9:Z40").AdvancedFilter xlFilterCopy, CopyToRange:=Feuil14.Range("N2:N15"), Unique:=True
Feuil5.Range("I4") = Feuil14.Range("N2").Value
Feuil5.Range("K4") = Feuil14.Range("N3").Value
Feuil5.Range("M4") = Feuil14.Range("N4").Value
Feuil5.Range("O4") = Feuil14.Range("N5").Value
Feuil5.Range("Q4") = Feuil14.Range("N6").Value
Feuil5.Range("S4") = Feuil14.Range("N7").Value
Feuil5.Range("U4") = Feuil14.Range("N8").Value
Feuil5.Range("W4") = Feuil14.Range("N9").Value
Feuil5.Range("Y4") = Feuil14.Range("N10").Value
'Remplacer l
Set Compid = Feuil14.Range("B:B").Find(what:=Range("I4").Value, LookIn:=xlValues, lookat:=xlWhole)
Range("J4").Value = Compid.Offset(, 8).Value
Set Compid = Feuil14.Range("B:B").Find(what:=Range("K4").Value, LookIn:=xlValues, lookat:=xlWhole)
Range("L4").Value = Compid.Offset(, 8).Value
Set Compid = Feuil14.Range("B:B").Find(what:=Range("M4").Value, LookIn:=xlValues, lookat:=xlWhole)
Range("N4").Value = Compid.Offset(, 8).Value
Set Compid = Feuil14.Range("B:B").Find(what:=Range("O4").Value, LookIn:=xlValues, lookat:=xlWhole)
Range("P4").Value = Compid.Offset(, 8).Value
Set Compid = Feuil14.Range("B:B").Find(what:=Range("Q4").Value, LookIn:=xlValues, lookat:=xlWhole)
Range("R4").Value = Compid.Offset(, 8).Value
Set Compid = Feuil14.Range("B:B").Find(what:=Range("S4").Value, LookIn:=xlValues, lookat:=xlWhole)
Range("T4").Value = Compid.Offset(, 8).Value
Set Compid = Feuil14.Range("B:B").Find(what:=Range("U4").Value, LookIn:=xlValues, lookat:=xlWhole)
Range("V4").Value = Compid.Offset(, 8).Value
Set Compid = Feuil14.Range("B:B").Find(what:=Range("W4").Value, LookIn:=xlValues, lookat:=xlWhole)
Range("X4").Value = Compid.Offset(, 8).Value
Set Compid = Feuil14.Range("B:B").Find(what:=Range("Y4").Value, LookIn:=xlValues, lookat:=xlWhole)
Range("Z4").Value = Compid.Offset(, 8).Value
End SubBonjour,
N'est-ce pas goto sans espace ?
ric
If range("AR4" & "AS4") ???
If Range("AR4")="" And Range("AS4") = ""Et :
Then Goto....Y
Bonjour à tous ...
goto line1
donc plus bas, tu doit écrire
line1: et non line 1 :
ric
