Format date dans export XML
Je ne sais pas comment forcer le format de la date (YYY-MM-DD) dans l'export .xml de ma feuille de calcule.
Voilà comment se fait l'export :
Sub export_XML()
    Dim fname As String
    ChDir "/Volumes/DIFFUSION/_GRILLES_EXCEL/Programme_xml/" '<- à adapter'
    fname = "programme - " & Format(Date, "yyyy-mm-dd") & ".xml"  '<- à adapter'
    Dim fsT As Object
    XMLstring = "<XML version=""1.0"" encoding=""UTF-8"">" & vbNewLine & "<Grille-des-programmes>"
    For Each ws In ThisWorkbook.Worksheets
        Select Case ws.Name
            Case "Lundi", "Mardi", "Mercredi", "Jeudi", "Vendredi", "Samedi", "Dimanche"
                With ws
                    DL = .Cells(Rows.Count, 1).End(xlUp).Row
                    For i = 3 To DL
                        If .Cells(i, 6) <> "PUB" And .Cells(i, 6) <> "Comblage / BA" And .Cells(i, 6) <> "Programme court" Then 'exclure PUB comblage / BA et Programme court
                            XMLstring = XMLstring & vbNewLine & vbTab & "<Day day=""" & ws.Name & """>"
                            For col = 1 To 9
                                If .Cells(i, col) <> "" Then XMLstring = XMLstring & vbNewLine & vbTab & vbTab & "<" & .Cells(2, col) & ">" & .Cells(i, col).Text & "</" & .Cells(2, col) & ">"
                            Next col
                            XMLstring = XMLstring & vbNewLine & vbTab & "</Day>"
        End Select
    Next ws
    XMLstring = XMLstring & vbNewLine & "</Grille-des-programmes>" & vbNewLine & "</XML>"
    Open fname For Output As 1
    Print #1, Encode_UTF8(XMLstring)
    Close 1
    MsgBox "Le fichier **  " & fname & "  ** a bien été créé"
Public Function Encode_UTF8(astr)
    Dim c
    Dim n
    Dim utftext
    utftext = ""
    n = 1
    Do While n <= Len(astr)
        c = AscW(Mid(astr, n, 1))
        If c < 128 Then
            utftext = utftext + Chr(c)
        ElseIf ((c >= 128) And (c < 2048)) Then
            utftext = utftext + Chr(((c \ 64) Or 192))
            utftext = utftext + Chr(((c And 63) Or 128))
        ElseIf ((c >= 2048) And (c < 65536)) Then
            utftext = utftext + Chr(((c \ 4096) Or 224))
            utftext = utftext + Chr((((c \ 64) And 63) Or 128))
            Else ' c >= 65536
                utftext = utftext + Chr(((c \ 262144) Or 240))
                utftext = utftext + Chr(((((c \ 4096) And 63)) Or 128))
            n = n + 1
        Loop
        Encode_UTF8 = utftext
End Function
Voici comment sort mon .xml
capture d ecran 2022 06 28 a 11 47 54
Et voici la feuille de calcul
capture d ecran 2022 06 28 a 11 48 09
Je pourrais faire une version plus légère du fichier si besoin mais en version intégrale il est trop lourd pour être partagé ...
En vous remerciant par avance,
Rechercher des sujets similaires à "format date export xml"
