Bonjour masoyann, le forum,
Un début de réponse.....
Doubleclic en E3 pour la question
Doubleclic en E5 pour la réponse
Dim question As String, reponse As String
Dim derlig As Integer, lig As Integer
Dim plageR As Range
derlig = Range("B" & Rows.Count).End(xlUp).Row
Set plageR = Range("B4:C" & derlig)
If Not Application.Intersect(Target, Range("E3")) Is Nothing Then
lig = Int(derlig * Rnd) + 1
question = Range("B" & lig).Value: Range("F3") = question: Range("F5").ClearContents
If Not Application.Intersect(Target, Range("E5")) Is Nothing Then
On Error Resume Next
If Range("F3") <> "" Then reponse = WorksheetFunction.VLookup(Range("F3"), plageR, 2, False)
Range("F5") = IIf(IsError(reponse), "", reponse)
