Erreur de compilation nom ambigu détecté worksheet_change
Je souhaite que les 2 codes fonctionnent mais j'ai le message d'erreur "erreur de compilation nom ambigu détecté worksheet_change".
Comment compiler mes formules, j'ai regardé quelques tutos mais je ne comprends pas comment faire.. merci d'avance,
Dim Larg As Double
Dim Haut As Double
Dim HautOrig As Double
Dim ColDeb As Integer
Dim ColFin As Integer
ColDeb = 9 'Colonne I
ColFin = 15 'Colonne O
If Target.Column >= ColDeb And Target.Column <= ColFin And Target.Count = 1 Then
HautOrig = Target.Parent.Rows(Target.Row).RowHeight 'On mémorise la hauteur de la ligne
If Target.Value = "" Or Trim(Target.Value) = "" Then 'Si la cellule est vide, on supprimer la forme
On Error Resume Next
ActiveSheet.Shapes("Rond" & Target.Row & "_" & Target.Column).Delete
On Error GoTo 0
Target.Parent.Rows(Target.Row).RowHeight = HautOrig
ActiveSheet.Shapes("Rond" & Target.Row & "_" & Target.Column).Delete 'Suppression ancienne forme
On Error GoTo 0
Feuil1.Shapes(Target.Value).Copy
If Err.Number = 0 Then
ActiveSheet.Paste
With Selection
.Name = "Rond" & Target.Row & "_" & Target.Column
.Visible = True
Larg = Feuil1.Shapes(Target.Value).Width
Haut = Feuil1.Shapes(Target.Value).Height
With Selection.ShapeRange 'Forme au centre de la cellule
.Left = Target.Left + (Target.Width - Larg) / 2
.Top = Target.Top + (Target.Height - Haut) / 2
If Haut + 4 > HautOrig Then 'Ajuste la hauteur de ligne
Target.Parent.Rows(Target.Row).RowHeight = Haut + 4
Target.Parent.Rows(Target.Row).RowHeight = HautOrig 'Hauteur d'origine
Target.Select
On Error GoTo 0
MajBarresFeuil6
Dim Oldvalue As String
Dim Newvalue As String
On Error GoTo Exitsub
If Not Intersect(Target, Range("G14:G300")) Is Nothing Then
If Target.SpecialCells(xlCellTypeAllValidation) Is Nothing Then
GoTo Exitsub
Else: If Target.Value = "" Then GoTo Exitsub Else
Newvalue = Target.Value
Application.Undo
Oldvalue = Target.Value
If Oldvalue = "" Then
Target.Value = Newvalue
If InStr(1, Oldvalue, Newvalue & ", ") > 0 Then
Target.Value = Replace(Oldvalue, Newvalue & ", ", "")
ElseIf InStr(1, Oldvalue, ", " & Newvalue) > 0 Then
Target.Value = Replace(Oldvalue, ", " & Newvalue, "")
ElseIf InStr(1, Oldvalue, Newvalue) = 0 Then
Target.Value = Oldvalue & ", " & Newvalue
Exitsub:
et est ce que c'est possible que l'lorsque je rentre plusieurs choix, ils se mettent en dessous l'un après l'autre et non à la suite ?
Merci,,
Bonjour Séverine,
Tu as 2 X la même Sub() d'où nom ambigu.
Tout ce qui concerne un événement DOIT être codé dans UNE seule et même Sub() de cet événement en y précisant chaque fois, évidemment, à quel élément particulier il se rapporte.
Petit détail pratique : quand tu veux insérer du code dans un message, histoire que ce soit lisible, utilise l'icône </> dans la barre d'outil de la fenêtre d'édition du message.
Pour le reste, d'abord le petit café du matin et la promenade des chiens. Oula, sacré ça, ici, pour madame!
bonjour salafia, salut Curilis,
je pense à ceci (sans fichier )
     Dim Larg  As Double
     Dim Haut  As Double
     Dim ColDeb As Integer: ColDeb = 9       'Colonne I
     Dim ColFin As Integer: ColFin = 15      'Colonne O
     Dim c As Range, shp As Shape, ShpNew
     '************** partie 1 ************************************************************
     Set c = Intersect(Target, Range("G14:G300"))     'juste les cellules modifiés de cette plage
     If Not c Is Nothing And c.Cells.CountLarge = 1 Then     's'iln'y a qu'une seule cellule modifiée
          If Len(Trim(c.Value2)) > 0 Then    'cellule n'est pas vide
               s = c.Validation.Formula1     'specialcells triggers un évenement !
               On Error GoTo 0
               If Err.Number = 0 Then        'cellule contient validation
                    Newvalue = c.Value
                    Application.Undo
                    Oldvalue = c.Value
                              c.Value = Replace(Oldvalue, Newvalue & ", ", "")
                              c.Value = Replace(Oldvalue, ", " & Newvalue, "")
                              c.Value = Oldvalue & ", " & Newvalue
          MajBarresFeuil6
     '************** partie 2 ************************************************************
     If ColDeb <= Target.Column And Target.Column <= ColFin And Target.Count = 1 Then
          HautOrig = Target.RowHeight        'On mémorise la hauteur de la ligne
          Me.Shapes("Rond" & Target.Row & "_" & Target.Column).Delete     'on efface toujours ce shape, s'il existe
          On Error GoTo 0
          If Trim(Target.Value) = "" Then    'Si la cellule est vide, on supprimer la forme
               Target.RowHeight = HautOrig
               i = Me.Shapes.Count
               Set shp = Feuil1.Shapes(Target.Value)
               On Error GoTo 0
               If Not shp Is Nothing Then
                    shp.Copy
                    DoEvents: DoEvents: DoEvents: DoEvents: DoEvents     'pacienter un peu
                    ActiveSheet.Paste
                    Set ShpNew = Me.Shapes(i + 1)     'nouveau shape dans cette feuille
                    On Error GoTo 0
                    If Not ShpNew Is Nothing Then
                         With ShpNew
                              .Visible = True
                              .Left = Target.Left + (Target.Width - shp.Width) / 2
                              .Top = Target.Top + (Target.Height - shp.Height) / 2
                              If .Height + 4 > HautOrig Then     'Ajuste la hauteur de ligne
                                   Target.RowHeight = .Height + 4
                                   Target.RowHeight = HautOrig     'Hauteur d'origine
                    Target.Select
Merci pour vos retours. En effet avec un fichier c'est toujours mieux!
En fait j'ai un fichier dont je souhaite pouvoir intégrer des barres de progression de l'action. (par contre la page gouv asso les barres ne fonctionnent pas bien..il y a un décalage j'ai l'impression...)
Puis j'ai souhaité en colonne G sur les différentes feuilles intégrer une liste déroulantes à choix multiples (et que les choix se mettent l'un après l'autre et centré).
Dès que je tente des codes, les 2 souhaits ne fonctionnent pas ensemble ...
24plan-action-v2.xlsm (94.18 Ko)
Une aide me serait très précieuse, car je galère depuis plusieurs jours...
Un GRAND MERCI d'avance,
Rechercher des sujets similaires à "erreur compilation nom ambigu detecte worksheet change"
