Salut Yoda,
alors j'ai fouiné dans l'explorateur d'objets (F2 depuis Visual Studio) et DashStyle n'est pas membre de la classe Series mais de celle de LineFormat.
Infos extraites de l'aide (F1 depuis Visual Studio) :
Returns or sets the dash style for the specified line. Can be one of the MsoLineDashStyle contants. Read/write Long.
Syntax
expression.DashStyle
expression A variable that represents a LineFormat object.
Example
This example adds a blue dashed line to myDocument.
Visual Basic for Applications
Set myDocument = Worksheets(1)
With myDocument.Shapes.AddLine(10, 10, 250, 250).Line
.DashStyle = msoLineDashDotDot
.ForeColor.RGB = RGB(50, 0, 128)
MsoLineDashStyle Enumeration
Specifies the dash style for a line.
- Name Value Description
msoLineDash 4 Line consists of dashes only.
msoLineDashDot 5 Line is a dash-dot pattern.
msoLineDashDotDot 6 Line is a dash-dot-dot pattern.
msoLineDashStyleMixed -2 Not supported.
msoLineLongDash 7 Line consists of long dashes.
msoLineLongDashDot 8 Line is a long dash-dot pattern.
msoLineRoundDot 3 Line is made up of round dots.
msoLineSolid 1 Line is solid.
msoLineSquareDot 2 Line is made up of square dots.
Voilou!
et pour le code, tu as des balises dédiées, juste à coté de celles que tu as utilisées là!
