regarde du coté de
Application.GetOpenFilename
EDIT : Avec peut-être préalablement :
Sub SelectFolder()
Dim sFolder As String
' Open the select folder prompt
With Application.FileDialog(msoFileDialogFolderPicker)
If .Show = -1 Then ' if OK is pressed
sFolder = .SelectedItems(1)
If sFolder <> "" Then ' if a file was chosen
' put your code in here
