Allouer un calcul dans VBA à une cellule avec loop
je voudrais alloué le résultat d'un calcul à une selection de cellule mais je bloque sur cette partie de mon code global à pour but d'exporter les noms de produits et la marge sur coût (Margin) calculé via le code vers un fichier CSV.
Pouvez vous m'aider?
compute the Margin into cell C32 to J32
    Range("C32").Select
        Do Until MARGIN = 0
    MARGIN = ActiveCell.Value
        ActiveCell.Offset(0, 1).Select
        Loop
Sub test()
Dim TEXT_LINE As String                                 ' Text line
    ' Variables for my differents fields
    Dim BIKE_TYPE As String                                 ' Type of bicycle produced
    Dim MARGIN As Double                                    ' Margin = Selling price without VAT - Cost excluding VAT
    Dim COST As Double                                      ' Total cost for producing the bicycle (excluding VAT)
    Dim SELL_PRICE As Double                                ' Selling price of bicycle without VAT
    Dim FilePath As String                                  ' The path for accessing to the the text file
    Dim NUMBER_OF_BICYCLES As Integer                       ' Number of bicyles to be produced
    Dim TOTAL As Double
    TOTAL = 0
    'create a new sheet "MARGIN" that will be exported later to CSV
Sheets.Add.Name = "MARGIN"
'Go back to sheet "BICYCLES"
Sheets("BICYCLES").Select
'Copy paste transpose the product name into sheet "MARGIN"
    Range("C2").Select
    Range("C2:J2").Select
    Selection.Copy
    Sheets("MARGIN").Select
    Range("A1").Select
    Selection.PasteSpecial Paste:=xlPasteAll, Operation:=xlNone, SkipBlanks:= _
        False, Transpose:=True
'Go back to sheet "BICYCLES" to calcul the margin
    Range("C2").Select                                      ' Select cell C2
    Do While ActiveCell.Value <> "COST EXCLUDING VAT (TAX)"
    BIKE_TYPE = ActiveCell.Value
    MsgBox ("BIKE_TYPE: " & BIKE_TYPE)
    ActiveCell.Offset(23, 0).Select                         ' Go to Row 25 - Cost excluding VAT
    COST = ActiveCell.Value
    MsgBox ("COST: " & COST)
    ActiveCell.Offset(1, 0).Select                          ' Go to Row 26 - Selling Price without VAT
    SELL_PRICE = ActiveCell.Value
    MsgBox ("SELL_PRICE: " & SELL_PRICE)
    ActiveCell.Offset(5, 0).Select                          ' Go to Row 31 for Quantity of Bicycles to produce
    NUMBER_OF_BICYCLES = ActiveCell.Value
    MsgBox ("NUMBER_OF_BICYCLES: " & NUMBER_OF_BICYCLES)
    MARGIN = (SELL_PRICE - COST) * NUMBER_OF_BICYCLES       ' Formula to compute Margin for number of bicyles produced for each type
    MsgBox ("MARGIN: " & MARGIN)
'compute the Margin into cell C32 to J32
    Range("C32").Select
        Do Until MARGIN = 0
        Loop
   Loop
'Copy paste transpose the calculated MARGIN into sheet "MARGIN"
     Range("C32").Select
    Range("C32:J32").Select
    Selection.Copy
    Range("B1").Select
  Range("C32:J32").Clear
    ' Totalization
    'TOTAL = TOTAL + MARGIN
    'ActiveCell.Offset(-29, 1).Select                        ' Go to next column at Row 2 for Margin of next bike type
    'Sheets("MARGIN").Select
   ' Cells(1, 2).Select
    'MARGIN = (SELL_PRICE - COST) * NUMBER_OF_BICYCLES
    ' Do While MARGIN <> ""
        ' Store the value in the current cell
     '   ActiveCell.Value = MARGIN
      ' Totalize my values
       ' TOTAL = TOTAL + MARGIN
        ' Select next cell in the same column (Go Down)
        'ActiveCell.Offset(1, 0).Select
  ' Loop
'Application.DisplayAlerts = False
'Sheets("MARGIN").Delete
'Application.DisplayAlerts = True
Salut,
Pas de fichier, pas de réponse ??
J'ai trouver la solution par moi meme. Merci
Rechercher des sujets similaires à "allouer calcul vba loop"
