Ajouter "Non" avec la couleur 38 par exemple
a
Bonjour le forum,
Quelles modifs apporter dans les macros suivantes pour ajouter "Non" de couleur 38 par exemple
Merci à vous
Private Sub Workbook_BeforeSave(ByVal SaveAsUI As Boolean, Cancel As Boolean)
Dim LastRow$, firstRow$
Dim sh As Worksheet
For Each sh In ThisWorkbook.Worksheets
If sh.Name <> "aaa" Then sh.Visible = xlSheetVeryHidden
LastRow = sh.Range("A" & Rows.Count).End(xlUp).Row + 1
sh.Rows(LastRow & ":" & 200).EntireRow.Hidden = True
Next sh
Sheets(1).Select
Private Sub Workbook_Open()
Dim sh As Worksheet
sh.Visible = xlSheetVisible
sh.Unprotect
sh.Protect UserInterfaceOnly:=True
sh.Rows("1:200").Hidden = False
Next sh
Sheets(1).Select
Range("A1").Select
Private Sub Workbook_SheetChange(ByVal sh As Object, ByVal Target As Range)
If Not Intersect(Target, Range("A3:A" & Rows.Count)) Is Nothing Then
If Not IsDate(Target) Then
Target.Resize(, 4).ClearContents
Range("B" & Target.Row) = sh.Name
Range("C" & Target.Row) = "Oui"
Range("D" & Target.Row) = IIf(Target = "", "", CDate(Cells(Target.Row, 1)))
Target = IIf(Target = "", "", Application.Proper(Format(CDate(Cells(Target.Row, 4)), "dddd dd mmmm yyyy")))
Range("A1").Select
Private Sub Workbook_SheetBeforeDoubleClick(ByVal sh As Object, ByVal Target As Range, Cancel As Boolean)
Dim Indice As Integer, NbColonne As Integer
Dim Tb, TbCoul, X, TbFont, Label As String
Dim Ligne As Integer
If Target.Address = "$A$2" Then Application.Run ("AfficherMasquerLignesVides")
Cancel = True
If Target.Address = "$A$2" Then Application.Run ("DeprotegerFeuilles")
Cancel = True
Select Case UCase(sh.Name)
Case "aaa", "bbb", "ccc", "ddd", "eee", "fff", "ggg", _
"hhh", "iii", "jjj", "kkk", "lll", "mmm", "nnn"
NbColonne = 2
End Select
Ligne = Range("A" & Rows.Count).End(xlUp).Row
If (Target.Row = Ligne And Range("A" & Ligne) <> "") Or (Target.Row = Ligne + 1 And Range("A" & Ligne + 1) = "") Then
If Target.Column = NbColonne + 1 And Target.Row >= 3 Then
TbFont = Array(5, 1)
TbCoul = Array(35, 40)
Tb = Array("", "Oui")
Cancel = True
X = UCase(Trim(Target))
If UBound(Filter(Tb, X, compare:=vbTextCompare)) >= 0 Then
Indice = Application.Match(X, Tb, 0) Mod (1 + UBound(Tb))
Label = Tb(Indice)
With Target
.Value = Label
.Interior.ColorIndex = TbCoul(Indice)
.Font.ColorIndex = TbFont(Indice)
With ActiveCell.Offset(0, -NbColonne).Resize(1, NbColonne)
If Label = "Oui" Then
.Font.Strikethrough = True
Target.Offset(, 1).Value = Date
Target.Offset(, -2) = Application.Proper(Format(Date, "dddd dd mmmm yyyy"))
Target.Offset(, -1).Value = sh.Name
.Font.Strikethrough = False
Target.Offset(, 1).ClearContents
Target.Offset(, -2).ClearContents
Target.Offset(, -1).ClearContents
Range("A1").Select
a
Bonjour le forum
J'ai réussi à faire quelque chose qui fonctionne
Macro ci-dessous
Mais je voudrais faire mettre en interior color 7 lorsque je met Non toute la ligne colonne A à E
Merci à vous
Cancel = True
Select Case UCase(sh.Name) ' Cette ligne permet de modifier l'onglet. Exemple "Couette Hiver" à la place de "COUETTE HIVER" sans modifier la macro "COUETTE HIVER"
NbColonne = 2
End Select
If Target.Column = NbColonne + 1 And Target.Row >= 3 Then ' And Range("A" & Target.Row) <> "" Then
TbFont = Array(5, 1, 1)
TbCoul = Array(35, 40, 7)
Tb = Array("", "Oui", "Non")
Cancel = True
Label = Tb(Indice)
With Target
.Value = Label
ElseIf Label = "Non" Then
Range("A1").Select
sans fichier.... c'est jamais facile de proposer une solution car on ne peut pas la tester..;
aller je me tente :
a remplacer par
range(cells(target.row,"a"),cells(target.row,"E")).Interior.ColorIndex = 7
Fred
a
Bonjour fred2406
Avec un peu de retard je te répond que ça fonctionne.
Sans fichier pas facile voir impossible très souvent.
Merci à toi et bonne journée
