[Calc] - Jeu des bâtons
Démo:
20210922 200136
Le code:
'=============================Jeu crée par ImoKa
'=============================v1.5
Option Compatible
Dim oDialogue As Object
Sub boite
    initialisation
    oDialogue=CreateUnoDialog(DialogLibraries.Standard.Dialog1)
    oDialogue.execute()
Dim label(19) As String
Dim tour As String
Dim x As Integer
Dim secondes As Double
Dim fin As Boolean
Dim joue_IA As Boolean
Sub initialisation
    x = 0
    secondes = 0.00000001
    fin = false
    joue_IA = false
    tour = "joueur"
    For i=0 To 19
        label(i) = "Label"+(i+1)
Sub allumette1
    Dim timer_avant As Long
    If tour = "joueur" and joue_IA = false Then
        timer_avant = Timer
        Do While Timer < timer_avant + secondes
            DoEvents
        Loop
            For i=0 To 19
                oDialogue.getControl(label(x)).Model.PositionY = 25+i
        oDialogue.getControl("Label21").Text = "Au tour de l'IA, patience"
    ElseIf joue_IA = true Then
        oDialogue.getControl("CommandButton1").Model.BackgroundColor = 15658734
        oDialogue.getControl("CommandButton2").Model.BackgroundColor = 15658734
        oDialogue.getControl("CommandButton3").Model.BackgroundColor = 15658734
        timer_avant = Timer
            DoEvents
        Loop
            For i=0 To 19
                oDialogue.getControl(label(x)).Model.PositionY = 25-i
        oDialogue.getControl("Label21").Text = "A ton tour"
        oDialogue.getControl("CommandButton1").Model.BackgroundColor = 13421772
        oDialogue.getControl("CommandButton2").Model.BackgroundColor = 13421772
        oDialogue.getControl("CommandButton3").Model.BackgroundColor = 13421772
    x = x+1
    verification
    If tour = "joueur" and fin = false Then
        IA
Sub allumette2
        timer_avant = Timer
            DoEvents
        Loop
            For i=0 To 19
                oDialogue.getControl(label(x+1)).Model.PositionY = 25+i
        timer_avant = Timer
            DoEvents
        Loop
            For i=0 To 19
                oDialogue.getControl(label(x+1)).Model.PositionY = 25-i
    x = x+2
    verification
        IA
Sub allumette3
        timer_avant = Timer
            DoEvents
        Loop
            For i=0 To 19
                oDialogue.getControl(label(x+2)).Model.PositionY = 25+i
        timer_avant = Timer
            DoEvents
        Loop
            For i=0 To 19
                oDialogue.getControl(label(x+2)).Model.PositionY = 25-i
    x = x+3
    verification
        IA
Sub bouton1
    allumette1
Sub bouton2
    allumette2
Sub bouton3
    allumette3
Sub IA
    Dim nombre As Integer
    nombre = Int(Rnd * 3)
    tour = "IA"
    joue_IA = true
    If nombre = 1 Then
        allumette1
    ElseIf nombre = 2 Then
        allumette2
    ElseIf nombre = 3 Then
        allumette3
        If Int(Rnd * 2) MOD 2 = 0 Then
            allumette1
            allumette3
    tour = "joueur"
    joue_IA = false
Sub verification
    If x = 20 and tour = "joueur" Then
        MsgBox(prompt:="Bravo !!!!"&Chr(10)&Chr(10)&"Tu as gagné")
        fin = true
    ElseIf x = 20 and tour = "IA" Then
        MsgBox(prompt:="Dommage"&Chr(10)&Chr(10)&"Tu as perdu")
        fin = true
    If fin = true Then
        oDialogue.endExecute()
Bonne Journée
61jeu-batons.ods (12.87 Ko)
PS: Je l'ai proposé aux téléchargements mais Sébastien à refusé
Rechercher des sujets similaires à "calc jeu batons"
