Envoyer mails avec Gmail à partir d'Excel
Bonjour :
Je voulais envoyer des mails avec Gmail à partir d'Excel. Voici programme :
Sub Test()
MailEnvoi "smtp.googlemail.com", True, "pao@distrame.fr", "PASSWORD", 465, 10, "pao@distrame.fr", "pao@distrame.fr", "stg.pao@distrame.fr", "Suivi des modifications.", "tel truc a été modifile", ""
Public Sub MailEnvoi(Serveur, Identify, User, PassWord, Port, Delay, Expediteur, Dest, DestEnCopy, Objet, Body, Pj)
' sub pour envoyer les mails
Dim msg
Dim Conf
Dim Config
Dim ess
Dim splitPj
Dim IsplitPj
Set msg = CreateObject("CDO.Message") 'pour la configuration du message
Set Conf = CreateObject("CDO.Configuration") ' pour la configuration de l'envoi
Dim strHTML
Set Config = Conf.Fields
' Configuration des parametres d'envoi
'(SMTP - Identification - SSL - Password - Nom Utilisateur - Adresse messagerie)
With Config
If Identify = True Then
.Item("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = True
.Item("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = 1
.Item("http://schemas.microsoft.com/cdo/configuration/sendusername") = User
.Item("http://schemas.microsoft.com/cdo/configuration/sendpassword") = PassWord
.Item("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = Port
.Item("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
.Item("http://schemas.microsoft.com/cdo/configuration/smtpserver") = Serveur
.Item("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = Delay
.Update
'Configuration du message
'If E_mail.Sign.Value = Checked Then Convert ServeurFrm.SignTXT, ServeurFrm.Text1
With msg
Set .Configuration = Conf
.To = Dest
.cc = DestEnCopy
.FROM = Expediteur
.Subject = Objet
.HTMLBody = Body '"<p align=""center""><font face=""Verdana"" size=""1"" color=""#9224FF""><b><br><font face=""Comic Sans MS"" size=""5"" color=""#FF0000""></b><i>" & body & "</i></font> " 'E_mail.ZThtml.Text
If Pj <> "" Then
splitPj = Split(Pj & ";", ";")
For IsplitPj = 0 To UBound(splitPj)
If Trim("" & splitPj(IsplitPj)) <> "" Then
.AddAttachment Trim("" & splitPj(IsplitPj))
.Send 'envoi du message
' reinitialisation des variables
Set msg = Nothing
Set Conf = Nothing
Set Config = Nothing
En gros, j'ai crée une procédure MailEnvoi qui va faire le boulot. Par contre je sais pas si je dois mettre "465, 10" comme port parce que je ne sais pas comment voir la configuration.
J'ai eu une erreur d'exécution : Le code d'erreur de transport était 0x80040217 à la ligne
Quelqu'un a une solution?Merci d'avance
bonjour,
plus de précision sur la configuration Gmail smtp server ici
h2so4 a écrit :bonjour,
Bonjour :
Merci de m'avoir répondu. J'avais vu la page que vous m'avez montré, mais je n'ai pas compris ce qu'il faut faire :
- Port 465 (SSL requis).
Port 587 (TLS requis).
Adresses IP dynamiques autorisées
Qu'est-ce qu'il faut je configure exactement?
je pense au port 465 mais en combinaison avec un compte gmail pour l'authentification et l'envoyeur.
h2so4 a écrit :je pense au port 465 mais en combinaison avec un compte gmail pour l'authentification et l'envoyeur.
Je pense pareil. c'est ce que j'avais mis dans le programme. Mais la connexion ssl on peut s'en profiter comme ça ou il faut télécharger certain truc?
FrancisZheng a écrit :h2so4 a écrit :je pense au port 465 mais en combinaison avec un compte gmail pour l'authentification et l'envoyeur.
en principe tu peux en profiter comme ça. mais le compte mentionné dans ton code, ne me parait pas être un compte gmail. as-tu essayé de configurer ton compte Gmail dans outlook ?
Faut il forcement configurer gmail avec outlook?
Moi j'ai essayé avec ce code la et j'ai aussi une erreur avec Send.
Je comprends pas...
Nossila a écrit :Bonjour,
[/attachment]
non mais cela permet de vérifier que les paramètres utilisés sont corrects. Si cela fonctionne avec outlook, cela devrait aussi fonctionner via vba.
h2so4 a écrit :FrancisZheng a écrit :h2so4 a écrit :je pense au port 465 mais en combinaison avec un compte gmail pour l'authentification et l'envoyeur.
En fait c'est pas un mail xx@gmail.xx, mais c'est du gmail pour l'entreprise. Tout est pareil sauf que c'est @distrame.
Je vais télécharger Outlook ce soir pour voir la configuration. Bonne fin de journée et à demain.
moi aussi c'est du gmail pour l'entreprise, et je comprends vraiment pas quel code il faut mettre pour que ça marche...
j'ai testé tellement de truc... Besoin d'aide aussi
s'il s'agit d'une version gmail entreprise il faut demander au gestionnaire du serveur quels sont les paramètres à utiliser.
Bonjour à tous :
J'ai trouvé la solution. Avant d'envoyer des mails, il faut autoriser votre envoie sur gmail:
Cochez la case "Activer".
Ensuite, utilisez un de ces deux codes ci-dessous :
Sub test1()
Dim iMsg As Object
Dim iConf As Object
Dim strbody As String
Dim Flds As Variant
Set iMsg = CreateObject("CDO.Message")
Set iConf = CreateObject("CDO.Configuration")
iConf.Load -1 ' CDO Source Defaults
Set Flds = iConf.Fields
With Flds
.Item("http://schemas.microsoft.com/cdo/configuration/sendusername") = "**@gmail.**"
.Item("http://schemas.microsoft.com/cdo/configuration/sendpassword") = "**"
.Item("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "smtp.gmail.com"
.Item("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
.Update
With iMsg
Set .Configuration = iConf
.To = "**@gmail.**"
.CC = ""
.BCC = ""
.from = """**"" <**@gmail.**>"
.Subject = "Confirmation d'inscription"
.textBody = "Bonjour "
.Send
MsgBox "Votre message a bien été envoyé!"
Sub test2()
Dim Mail As New Message
Dim Config As Configuration: Set Config = Mail.Configuration
Config(cdoSendUsingMethod) = cdoSendUsingPort
Config(cdoSMTPServer) = "smtp.gmail.com"
Config(cdoSMTPServerPort) = 25
Config(cdoSMTPAuthenticate) = cdoBasic
Config(cdoSMTPUseSSL) = True
Config(cdoSendUserName) = "**@gmail.**"
Config(cdoSendPassword) = "**"
Config.Fields.Update
Mail.To = "**@gmail.**"
Mail.from = Config(cdoSendUserName)
Mail.Subject = "Subject from VBA"
Mail.HTMLBody = "Body from VBA"
Mail.Send
Problème résolu.
Mon problème = Ma recherche de résolution de l'erreur 0x80040217 ("Le message n'a pu être envoyé vers le serveur SMTP") a pris plusieurs semaines, aussi je ne résiste pas à vous communiquer humblement une solution. J'utilise Excel 2016, Windows 10 et la messagerie Gmail. J'envoie un message depuis un classeur Excel en VBA.
Ma solution = Il faut modifier les paramètres de votre messagerie Gmail de la façon suivante :
1. Ouvrir votre messagerie Gmail
2. Clic sur la flèche du bouton Paramètres de Gmail
3. Choisir Paramètres
4. Clic sur l’onglet « Compte et importation »
5. Choisir « Autres paramètres de votre compte »
6. Dans Préférences de compte : choisir « Accessibilité»
7. À gauche dans le bandeau « Mon compte » choisir « Connexion et sécurité »
8. Descendre en bas de la page jusqu’au paragraphe « Paramètre "Autoriser les applications moins sécurisées" et déplacer le curseur à droite pour activer cette fonction.
La référence "Microsoft CDO for Windows 2000 Library" doit être présente au niveau du classeur Excel (VBA / Outils / Références).
J'espère que cela fonctionnera pour vous.
