Je cherche à envoyer des emails en gros depuis une spreadsheet Excel via Outlook. Ma spreadsheet est nommée "EMAIL" avec les adresses email en A, prénom B, nom de famille en C, sujet de l'email to send en D, corps en E, attachement (files path) en F, date en G, et le statut (envoyé/en cours) en H.
Lors de l'exécution du script, j'obtiens ce message d'erreur:
"Run time error 9, subscript out of range"
Avec le debugging qui indique une erreur en ligne 3. Voici mon code:
Sub send_email()
Dim sh As Worksheet
Set sh = ThisWorkbook.Sheets("EMAIL")
Dim OA As Object
Dim msg As Object
Set OA = CreateObject("Outlook.Application")
Dim each_row As Integer
Dim last_row As Integer
last_row = Application.WorksheetFunction.CountA(sh.Range("A:A"))
For each_row = 2 To last_row
Set msg = OA.createitem(0)
msg.To = sh.Range("A" & each_row).Value
first_name = sh.Range("B" & each_row).Value
last_name = sh.Range("C" & each_row).Value
msg.cc = sh.Range("D" & each_row).Value
msg.Subject = sh.Range("E" & each_row).Value
msg.body = sh.Range("F" & each_row).Value
date_to_send = sh.Range("H" & each_row).Value
date_to_send = Format(date_to_send, "dd/mm/yyyy")
Status = sh.Range("I" & each_row).Value
current_date = Format(Date, "dd/mm/yyyy")
If date_to_send = current_date Then
If sh.Range("G" & each_row).Value <> "" Then
msg.attachments.Add sh.Range("G" & each_row).Value
Cells(each_row, 9).Value = "Sent"
Content = Replace(msg.body, "<>", first_name + " " + last_name)
msg.body = Content
msg.send
msg.body = Content
msg.send
Next each_row
Merci pour votre aide.
