Signature Outlook 2010 automatique à partir d'Excel VBA
J'ai lu des tutos mais je ne parviens pas à insérer ma signature enregistrée dans outlook 2010 après la sélection que je colle dans mon mail.
Voici mon bout de code, merci pour votre aide.
Sub EnvoyerParMail()
Dim oOutlook As Object
Set oOutlook = CreateObject("Outlook.Application")
Dim oMail As Object
Set oMail = oOutlook.CreateItem(0)
With oMail
Dim oObjetWord As Object
Set oObjetWord = .GetInspector.WordEditor
.To = "marin.marin@toto.fr"
.CC = "bateau.quinavigue@eau.com
.Subject = "Extraction du flux " & "- " & ThisWorkbook.Name
.Body = ActiveCell.Value
Selection.Copy
oObjetWord.Range(0).Paste
.Display
Bonjour plfiloo
Un code qui j'espère fonctionnera sous 2010
  Dim oMail As Object
  ' Créer une instance d'Outlook
  ' Créer une instance de mail
  With oMail
    .Display
    .To = "adresse@fai.fr"
    .CC = "adresse@fai.fr"
    .HTMLBody = RangetoHTML(Selection) & .HTMLBody
Function RangetoHTML(rng As Range)
' Changed by Ron de Bruin 28-Oct-2006
' Working in Office 2000-2016
    Dim fso As Object
    Dim ts As Object
    Dim TempFile As String
    Dim TempWB As Workbook
    TempFile = Environ$("temp") & "\" & Format(Now, "dd-mm-yy h-mm-ss") & ".htm"
    'Copy the range and create a new workbook to past the data in
    rng.Copy
    Set TempWB = Workbooks.Add(1)
    With TempWB.Sheets(1)
        .Cells(1).PasteSpecial Paste:=8
        .Cells(1).PasteSpecial xlPasteValues, , False, False
        .Cells(1).PasteSpecial xlPasteFormats, , False, False
        .Cells(1).Select
        On Error Resume Next
        .DrawingObjects.Visible = True
        .DrawingObjects.Delete
        On Error GoTo 0
    'Publish the sheet to a htm file
    With TempWB.PublishObjects.Add( _
         SourceType:=xlSourceRange, _
         Filename:=TempFile, _
         Sheet:=TempWB.Sheets(1).Name, _
         Source:=TempWB.Sheets(1).UsedRange.Address, _
         HtmlType:=xlHtmlStatic)
        .Publish (True)
    'Read all data from the htm file into RangetoHTML
    Set fso = CreateObject("Scripting.FileSystemObject")
    Set ts = fso.GetFile(TempFile).OpenAsTextStream(1, -2)
    RangetoHTML = ts.readall
    ts.Close
    RangetoHTML = Replace(RangetoHTML, "align=center x:publishsource=", _
                          "align=left x:publishsource=")
    'Close TempWB
    TempWB.Close savechanges:=False
    'Delete the htm file we used in this function
    Kill TempFile
    Set ts = Nothing
    Set fso = Nothing
    Set TempWB = Nothing
End Function
Merci Bruno,
Veuillez excuser le novice que je suis. Je dois copier/coller l'intégralité du code reçu.
Car en le copiant dans un module, je ne visualise pas la signature dans le mail.
C'est bon cela fonctionne Bruno. super.
Je souhaiterais pour parfaire le travail ajouter du littéral dans le corps du mail avant la copie des cellules...
Du genre : "Bonjour, vous trouverez ci-dessous etc;..."
D'avance merci
Plfiloo.
J'ai omis la suppression d'une ligne qui ne sert plus à rien
Pour ce qui est du texte,
  Dim oMail As Object
  Dim strHTML As String
  With oMail
    .Display
    ' Corps
    strHTML = ""
    strHTML = strHTML & "<HEAD>"
    strHTML = strHTML & "<BODY>"
    strHTML = strHTML & "Bonjour,<BR><BR>" _
          & "ma ligne suivante ici,<BR><BR>" _
    & "ma 3ème ligne"
    ' On complète le Body
    .HTMLBody = strHTML & RangetoHTML(Selection) & .HTMLBody
Sinon, tu trouveras d'autres exemples ICI
Rechercher des sujets similaires à "signature outlook 2010 automatique partir vba"
