Copier / Coller à la suite
J'aimerais coller une liste de données (dans le feuille "Outils)" à la suite d'une autre feuille ("Bilan Activité") sans écraser les données de celle-ci ("Feuille Bilan activité").
Voici le début de mon programme :
function COPIE() {
var spreadsheet = SpreadsheetApp.getActive(); spreadsheet.getRange('A8').activate();
var currentCell = spreadsheet.getCurrentCell(); spreadsheet.getSelection().getNextDataRange(SpreadsheetApp.Direction.DOWN).activate(); currentCell.activateAsCurrentCell();
spreadsheet.setActiveSheet(spreadsheet.getSheetByName('Bilan activité '), true);
spreadsheet.getRange('Outils!A8:A1000').copyTo(spreadsheet.getActiveRange(), SpreadsheetApp.CopyPasteType.PASTE_VALUES, false); spreadsheet.getRange('B8').activate();
spreadsheet.getRange('Outils!B8:B1000').copyTo(spreadsheet.getActiveRange(), SpreadsheetApp.CopyPasteType.PASTE_VALUES, false); spreadsheet.getRange('D8').activate();
spreadsheet.getRange('C8').activate();
spreadsheet.getRange('Outils!D8:D1000').copyTo(spreadsheet.getActiveRange(), SpreadsheetApp.CopyPasteType.PASTE_VALUES, false);
spreadsheet.getRange('E8').activate();
currentCell.activateAsCurrentCell(); spreadsheet.setActiveSheet(spreadsheet.getSheetByName('Bilan activité '), true);
spreadsheet.getRange('Outils!E8:E1000').copyTo(spreadsheet.getActiveRange(), SpreadsheetApp.CopyPasteType.PASTE_VALUES, false);
spreadsheet.getRange('H8').activate();
spreadsheet.setActiveSheet(spreadsheet.getSheetByName('Bilan activité '), true); spreadsheet.getRange('E8').activate();
spreadsheet.getRange('Outils!H8:H1000').copyTo(spreadsheet.getActiveRange(), SpreadsheetApp.CopyPasteType.PASTE_VALUES, false);
spreadsheet.getRange('I8').activate();
currentCell.activateAsCurrentCell(); currentCell = spreadsheet.getCurrentCell();
spreadsheet.getRange('F8').activate(); spreadsheet.getRange('Outils!I8:I1000').copyTo(spreadsheet.getActiveRange(), SpreadsheetApp.CopyPasteType.PASTE_VALUES, false);
spreadsheet.getRange('J19').activate();};
15code.txt (3.26 Ko)
Bonjour et bienvenue,
ton code est tellement complexe qu'il vaudrait mieux mettre un lien vers une copie de ton fichier
et cela permettrait d'éclaircir ce point ! ... "dans une feuille à la suite d'une autre feuille" c'est créer une 3ème feuille qui du coup ne va pas écraser la seconde.
Merci pour votre réponse.
Oui, il est vrai qu'un lien vers le fichier est mieux.
Le voici : https://docs.google.com/spreadsheets/d/1yVe8GJ9BxJC6Hf86E1OwKImywo-NeYPk0dI2MnC1ACA/edit?usp=sharing
La seconde feuille "Bilan activité" servira d'historique de saisie de la feuille "Outil"
Merci d'avance.
Bonjour;
il faut aussi autoriser le fichier (voir les autorisations)
Rechercher des sujets similaires à "copier coller suite"
