Amélioration Code VBA-Recherche v
je cherche un code afin d'améliorer la syntaxe de mon code suivant :
<Sub Affectation() 'ETAPE 4
Dim b As Single
Sheets("RESULTAT").Select
b = Cells(Rows.Count, 2).End(xlUp).Row
Columns("E:E").Select
Selection.Insert Shift:=xlToRight
Range("E1").Value = "NATURE JAL"
' Couleur ajoutée avec fond blanc à la colonne nouvellement créée
Range("E1").Select
With Selection.Interior
.Pattern = xlSolid
.PatternColorIndex = xlAutomatic
.Color = 10027161
.TintAndShade = 0
.PatternTintAndShade = 0
With Selection.Font
.ThemeColor = xlThemeColorDark1
.TintAndShade = 0
Selection.Font.Bold = True
'Recherche V pour mettre la nature des journaux en face de chaque code JAL
Range("E2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-1],JOURNAUX!C[-1]:C,2,FALSE)"
Range("E2").Select
Selection.AutoFill Destination:=Range("E2:E" & b)
Range("E2:E" & b).Select
Selection.Copy
:=False, Transpose:=False
'Recherchev pour affecter les éléments en fonction du MAPPING
Range("O2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-2],MAPPING!C[-13]:C[-12],2,FALSE)"
Range("P2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-4],MAPPING!C[-14]:C[-13],2,FALSE)"
Range("Q2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-4],MAPPING!C[-15]:C[-13],3,FALSE)"
Range("R2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-5],MAPPING!C[-16]:C[-12],5,FALSE)"
Range("S2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-6],MAPPING!C[-17]:C[-14],4,FALSE)"
Range("T2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-8],MAPPING!C[-18]:C[-13],6,FALSE)"
Range("U2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-9],MAPPING!C[-19]:C[-13],7,FALSE)"
Range("V2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-9],MAPPING!C[-20]:C[-15],6,FALSE)"
Range("W2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-10],MAPPING!C[-21]:C[-15],7,FALSE)"
Range("O2:W2").Select
Selection.AutoFill Destination:=Range("O2:W" & b)
Range("O2:W" & b).Select
Selection.Copy
Range("K1:W1").Select
.Pattern = xlSolid
.Color = 10027161
.TintAndShade = 0
With Selection.Font
.TintAndShade = 0
Cells.Select
Cells.EntireColumn.AutoFit
Range("A1").Select
Selection.ClearContents
Range("A1").Value = "DATE"
En VBA, il faut bannir les .Select et Selection chaque fois que c'est possible, c'est-à-dire toujours (ou presque) .
La variable b représente un nombre de lignes donc un entier, dans ce cas de type Long car susceptible de dépasser 65535, mais en aucun cas un nombre décimal (Single)
Dim b As Long
  With Worksheets("RESULTAT")
    .Columns("E:E").Insert Shift:=xlToRight
    With .Range("E1")
      .Interior.Color = 10027161
      .Font.ThemeColor = xlThemeColorDark1
      .Font.Bold = True
    b = .Cells(.Rows.Count, 2).End(xlUp).Row
    With .Range("E2:E" & b)
      .Value = .Value
    .Range("O2:O" & b).FormulaR1C1 = "=VLOOKUP(RC[-2],MAPPING!C[-13]:C[-12],2,FALSE)"
    .Range("P2:P" & b).FormulaR1C1 = "=VLOOKUP(RC[-4],MAPPING!C[-14]:C[-13],2,FALSE)"
    .Range("Q2:Q" & b).FormulaR1C1 = "=VLOOKUP(RC[-4],MAPPING!C[-15]:C[-13],3,FALSE)"
    .Range("R2:R" & b).FormulaR1C1 = "=VLOOKUP(RC[-5],MAPPING!C[-16]:C[-12],5,FALSE)"
    .Range("S2:S" & b).FormulaR1C1 = "=VLOOKUP(RC[-6],MAPPING!C[-17]:C[-14],4,FALSE)"
    .Range("T2:T" & b).FormulaR1C1 = "=VLOOKUP(RC[-8],MAPPING!C[-18]:C[-13],6,FALSE)"
    .Range("U2:U" & b).FormulaR1C1 = "=VLOOKUP(RC[-9],MAPPING!C[-19]:C[-13],7,FALSE)"
    .Range("V2:V" & b).FormulaR1C1 = "=VLOOKUP(RC[-9],MAPPING!C[-20]:C[-15],6,FALSE)"
    .Range("W2:W" & b).FormulaR1C1 = "=VLOOKUP(RC[-10],MAPPING!C[-21]:C[-15],7,FALSE)"
    With Range("O2:W" & b)
      .Value = .Value
    With .Range("K1:W1")
    .Columns.AutoFit
    .Range("A1").Value = "DATE"
Merci Patrice !!!
Rechercher des sujets similaires à "amelioration code vba recherche"
