Bonsoir Grandid, bonsoir le forum,
J'ai pour habitude de commenter mes codes mais comme de ton coté du n'as pas daigné fournir des explications précises, tu adapteras, si tu en as envie...
Sub Macro1()
Dim CD As Workbook
Dim OD As Worksheet
Dim CACS As String
Dim NCS As String
Dim CS As Workbook
Dim OS As Worksheet
Dim DL As Integer
Dim I As Integer
Dim R As Range
Set CD = ThisWorkbook
Set OD = CD.Worksheets(1)
CACS = "C:\blabla\tavequaledire\etcetc\"
NFS = "tavequaledire.xlsx"
On Error Resume Next
Set CS = Workbooks(CACS & NFS)
If Err > 0 Then
Err.Clear
Set CS = Workbooks.Open(CACS & NFS)
On Error GoTo 0
Set OS = CS.Worksheets(1)
DL = OD.Cells(Application.Rows.Count, "F").End(xlUp).Row
For I = 1 To DL
Set R = OS.Columns(1).Find(OD.Cells(I, "F").Value, , xlValues, xlWhole)
If Not R Is Nothing Then
OD.Cells(I, "G").Value = R.Offset(0, 1).Value
R = Nothing
Next I
