Erreur de type 13 Incompatibilité de type
J'ai un soucis au niveau de mon excel, tout fonctionnait bien auparavant et mtn, j'ai cette erreur
Function onlydigits(S As String) As String
Dim retval As String
Dim i As Integer
retval = ""
For i = 1 To Len(S)
If IsNumeric(Mid(S, i, 1)) Then
retval = retval + Mid(S, i, 1)
onlydigits = retval
End Function
Private Sub btn_loockup_Click()
'MsgBox lookuporigin
'Loockup for the event log and if exist open a new form to input/update the completion date, text
row_number = 3
veventid = CLng(onlydigits(txt_actionID.Text))
'MsgBox "digit only: " & vactionid
Do
DoEvents
row_number = row_number + 1
item_in_review = Sheets("Event Log").Range("B" & row_number)
vstatus = Sheets("Event Log").Range("AG" & row_number)
eventprefix = Sheets("Event Log").Range("A" & row_number)
If Sheets("Event Log").Range("G" & row_number) = "" Then
prod_code = Sheets("Event Log").Range("E" & row_number)
prod_code = Sheets("Event Log").Range("G" & row_number)
If Sheets("Event Log").Range("H" & row_number) = "" Then
prod_lot = Sheets("Event Log").Range("F" & row_number)
prod_lot = Sheets("Event Log").Range("H" & row_number)
'Update 11/jul/2017 Using the same lookup for to point to different sub form according if it's an action change, a REB or DRG request
If lookuporigin = "event" Then
If item_in_review = veventid And vstatus <> 1 Then
'MsgBox "Demande trouvée - " & vactionid & ""
'if record found open ActionCompletion form
Unload Me
Action.Show
Exit Sub
ElseIf lookuporigin = "REB" Then
If item_in_review = veventid Then
'MsgBox "Demande trouvée REB- " & eventprefix & "-" & veventid & ""
Unload Me
REB.Show
Exit Sub
ElseIf lookuporigin = "DRG" Then
'MsgBox "Demande trouvée DRG- " & veventid & ""
Unload Me
DRG.Show
Exit Sub
Loop Until item_in_review = ""
MsgBox "Event non trouvée ou déjà cloturée!"
eventprefix = ""
prod_code = ""
prod_lot = ""
Unload Me
Private Sub Rebutonly_Click()
'Update 01/12/2017 add button rebut only
Unload Me
REB.Show
Exit Sub
End SubL'erreur se situe au niveau du Action.Show
L'userform se nomme bien comme cela.. par contre les autres userform REB et DRG fonctionne correctement. Je suis bloqué
Merci pour l'aide
Ton vba est protégé par mot de passe.
Par contre au clic sur le bouton "Actions d'un Event" :
- Si on ne renseigne pas de numéro dans la case ID alors erreur 13 si on tente de cliquer sur rechercher.
-Si l'ID est renseigné alors ... Message box Event non trouvée ou déjà cloturée ! ( ... çà ferait mieux sans le e à cloturée )
pas testé tous les numéros pour en trouver 1 valide.
Faudrait ajouter 2 ou 3 ligne de code pour empêcher l'exécution de ta macro rechercher tant que la textbox ID n'est pas renseignée.
Le mdp est ISO
En fait il faut aller dans l'autre feuille pour voir un E ou D non clôturé mais dans tous les cas quand on rentre un E ou D non clôturé, on a quand meme le msg de type 13 :( Essaie de rentrer soit D-20419 ou 20419
J'ai repris cet excel VBA qui a été codé par une autre personne et qui ne code absolument pas comme moi et qui ne rentre pas autant d'info que moi du coup, j'ai vachement du mal a trouver l'erreur
le bug dans le code se situe à ce niveau la
Unload Me
Action.Show
Exit Sub
End IfAction.Show qui fait je pense référence à un userform du meme nom
