Insérer un image à partir d'un lien url
Bonjour ,
Je ne peux toujours pas insérer d'images à partir de l'URL et mon responsable m'a rapidement demandé d'ajouter 2156 photos
Pour le faire manuellement, il faudrait beaucoup de temple
J'ai vraiment besoin de votre aide
Invité
Voici du code qui permet d'importer les images et de les afficher en B
' ***** CODE PierreP56 : http://tatiak.canalblog.com/ *****
Sub Affiche_Images()
Dim rep As String, Ndf As String, lg As Integer, i As Integer
Dim Sh As Shape, Di() As String, W As Single
rep = ThisWorkbook.Path & "\Img\"
If Not Exist_Rep(rep) Then MkDir rep
With Sheets(1)
lg = .Cells(Rows.Count, "A").End(xlUp).Row
For i = 7 To lg
Ndf = Ndf_Img(.Cells(i, "A").Value)
With .Cells(i, "B")
If Exist_Fichier(rep & Ndf) Then
Di = Split(DimensionsImage(rep & Ndf), " x ")
W = CSng(Di(0)) / CSng(Di(1)) * .Height
Set Sh = Sheets(1).Shapes.AddPicture(rep & Ndf, True, True, _
.Left + (.Width / 2) - (.Height / 2), .Top, W, .Height)
Sh.Name = "_" & i
Function Ndf_Img(URL As String) As String
Dim rep As String, Ndf As String, Id As Integer
Ndf_Img = ""
If UCase(Right(URL, 4)) = ".JPG" Then
Ndf = Right(URL, InStr(1, StrReverse(URL), "/") - 1)
If Not Exist_Fichier(rep & Ndf) Then
Id = DownloadJPG(URL, rep & Ndf)
If Id >= 0 Then Ndf_Img = Ndf
Ndf_Img = Ndf
End Function
Function Exist_Rep(Ndf As String) As Boolean
On Error Resume Next
Exist_Rep = GetAttr(Ndf) And vbDirectory
End Function
Public Function Exist_Fichier(S As String) As Boolean
Dim tatiak As Object
Set tatiak = CreateObject("Scripting.FileSystemObject")
Exist_Fichier = tatiak.FileExists(S)
End Function
' Inspiré de => http://arkham46.developpez.com/articles/ofNdfe/ofNdfeweb/?page=page_5
Function DownloadJPG(URL As String, Ndf As String) As Integer
Dim f As Integer, buffer() As Byte
On Error GoTo errhdlr
With CreateObject("MSXML2.XMLHTTP")
.Open "GET", URL, False
.send
If .Status = 200 Then
f = FreeFile
Open Ndf For Binary As #f
buffer = .responseBody
Put #f, , buffer
Erase buffer
Close #f
DownloadJPG = 0
Exit Function
errhdlr:
DownloadJPG = -1
End Function
' par Excel-Malin.com ( https://excel-malin.com )
' https://excel-malin.com/codes-sources-vba/vba-trouver-hauteur-largeur-image/
Public Function DimensionsImage(Fichier As String) As String
Dim objShell As Object, objDossier As Object, objFichier As Object
Dim ImageDossier As Variant, ImageFichier As Variant, DimensionsI As Variant
On Error GoTo Erreur
ImageFichier = Mid(Fichier, InStrRev(Fichier, "\") + 1)
ImageDossier = Left(Fichier, Len(Fichier) - Len(ImageFichier))
Set objShell = CreateObject("Shell.Application")
Set objDossier = objShell.Namespace(ImageDossier)
Set objFichier = objDossier.ParseName(ImageFichier)
DimensionsI = CStr(objFichier.ExtendedProperty("Dimensions"))
DimensionsI = Left(DimensionsI, Len(DimensionsI) - 1)
DimensionsImage = Right(DimensionsI, Len(DimensionsI) - 1)
Set objShell = Nothing
Set objDossier = Nothing
Set objFichier = Nothing
Exit Function
Erreur:
DimensionsImage = ""
End FunctionPierre
merci beaucoup mais le problème importation des images prendre beaucoup de tempe
