Erreur sélection fichier
J'ai une macro excel qui ouvre une boîte de dialogue afin de sélectionner un fichier .csv et le convertir ( voir code ci-dessous . Le problème est que le fichier me renvoie l'erreur suivante, ai-je mis la mauvaise source ?
2020 05 11 09 06 17 microsoft visual basic
  Dim FD As Office.FileDialog
     Set FD = Application.FileDialog(msoFileDialogFilePicker)
     With FD
      .InitialFileName = ThisWorkbook.Path & "\*.csv"  'adapter le répertoire
     .Show
     If .SelectedItems.Count > 0 Then fichier = .SelectedItems(1)
 ActiveWorkbook.Queries.Add Name:="Customer_hotline", Formula:= _
        "let" & Chr(13) & "" & Chr(10) & "    Source = Csv.Document(File.Contents(" & fichier & "),[Delimiter="","", Columns=14, Encoding=65001, QuoteStyle=QuoteStyle.None])," & Chr(13) & "" & Chr(10) & "    #""En-têtes promus"" = Table.PromoteHeaders(Source, [PromoteAllScalars=true])," & Chr(13) & "" & Chr(10) & "    #""Type modifié"" = Table.TransformColumnTypes(#""En-têtes promus"",{{""CostType"", type text}, " & _
        "{""TicketID"", Int64.Type}, {""TicketType"", type text}, {""CompanyCode"", type text}, {""InterventionDay"", type date}, {""ServicePackage"", type text}, {""NoteCreatedByTeam"", type text}, {""NoteCreatedBy"", type text}, {""Title"", type text}, {""Amount"", type number}, {""Unit"", Currency.Type}, {""Total"", Int64.Type}, {""Billable"", type text}, {""Invoiced"", t" & _
        "ype logical}})" & Chr(13) & "" & Chr(10) & "in" & Chr(13) & "" & Chr(10) & "    #""Type modifié"""
    With ActiveSheet.ListObjects.Add(SourceType:=0, Source:= _
        "OLEDB;Provider=Microsoft.Mashup.OleDb.1;Data Source=$Workbook$;Location=Customer_hotline;Extended Properties=""""" _
        , Destination:=Range("$A$1")).QueryTable
        .CommandType = xlCmdSql
        .CommandText = Array("SELECT * FROM [Customer_hotline]")
        .RowNumbers = False
        .FillAdjacentFormulas = False
        .PreserveFormatting = True
        .RefreshOnFileOpen = False
        .BackgroundQuery = True
        .RefreshStyle = xlInsertDeleteCells
        .SavePassword = False
        .SaveData = True
        .AdjustColumnWidth = True
        .RefreshPeriod = 0
        .PreserveColumnInfo = False
        .ListObject.DisplayName = "Customer_hotline"
        .Refresh BackgroundQuery:=False
Merci de votre aide !
à quoi correspond la variable $Workbook$ ?
à vrai dire je ne sais pas trop, il n'y a rien dans le code que je vous ai pas envoyé qui l'a défini...
J'ai utilisé l’enregistreur de macro, et en sélectionnant manuellement mon fichier il m'a généré cette variable en tant que source.
PS : Je vous ai mis mon fichier en fichier joint si vous voulez y voir plus clair
Encore un grand merci pour votre aide
re,
essai en remplacant:
Source=$Workbook$
par
Source=" & fichier & "
Cela me renvoie toujours la même erreur : « le nom source n’a pas été reconnue. Veuillez vérifier qu’il est correctement orthographié »
re,
un essaie avec les $
remplacer:
Source=$Workbook$;
par
Source=$" & fichier & "$;
Salut le fil...
Une valeur typée avec un point devant c'est pas bizare ça...
testes
ou
.Refresh BackgroundQuery =False
bonjour,
merci pour votre réponse.
Si j’utilise votre première méthode en enlevant le premier « . » le script ne s’exécute plus et passe directement sur le debug.
Si j’enlève les « : » cela me redonne l’erreur suivant : Microsoft excel actualise des données. Merci de réessayer plus tard »
Rebonjour,
Même si j’ajoute des « $ » avant et après cela me renvoie toujours la même erreur lié à la source
Salut le fil...
Alors teste en doublant les guillemets
Source = Csv.Document(File.Contents(" "& fichier & "")
En rajoutant deux guillemets cela m’a changé le message d’erreur : « Le chemin d’accès du fichier spécifié doit être un chemin d’accès absolu valide »
Bé alors là ...
Coles un
Debug.Print fichier
aprés ton
En With
pour voir un peu ce que cela dis
j'ai ajouté votre ligne de code, mais je ne sais pas trop comment elle s'utilise.
J'ai exécuté mon script normalement à l'aide de mon bouton et j'ai de nouveau le même message
Je vous glisse mon fichier ci-joint, si vous voulez y voir plus clair
Re
C'est une bétise de guillemets
testes comme cela :
Source = Csv.Document(File.Contents(""" & fichier & """),
Oui comme ça c’est fonctionnel
Un grand MERCI pour votre aide !
Passez une bonne fin de semaine
Rechercher des sujets similaires à "erreur selection fichier"
