Ouverture d'une boite de dialogue afin de sélectionner un fichier
j
Rebonjour,
Voici un échantillon de mon code VBA :
ActiveWorkbook.Queries.Add Name:="Customer_hotline", Formula:= _
"let" & Chr(13) & "" & Chr(10) & " Source = Csv.Document(File.Contents(""C:\Customer_hotline.csv""),[Delimiter="","", Columns=14, Encoding=65001, QuoteStyle=QuoteStyle.None])," & Chr(13) & "" & Chr(10) & " #""En-têtes promus"" = Table.PromoteHeaders(Source, [PromoteAllScalars=true])," & Chr(13) & "" & Chr(10) & " #""Type modifié"" = Table.TransformColumnTypes(#""En-têtes promus"",{{""CostType"", type text}, " & _
"{""TicketID"", Int64.Type}, {""TicketType"", type text}, {""CompanyCode"", type text}, {""InterventionDay"", type date}, {""ServicePackage"", type text}, {""NoteCreatedByTeam"", type text}, {""NoteCreatedBy"", type text}, {""Title"", type text}, {""Amount"", type number}, {""Unit"", Currency.Type}, {""Total"", Int64.Type}, {""Billable"", type text}, {""Invoiced"", t" & _
"ype logical}})" & Chr(13) & "" & Chr(10) & "in" & Chr(13) & "" & Chr(10) & " #""Type modifié"""J'aimerais ajouter le bout de code ci-dessous qui permet l'ouverture d'une boîte de dialogue mais je ne sais pas ou le placé :
Application.GetOpenFilename()Merci d'avance pour votre aide !
voici un exemple,
Dim FD As Office.FileDialog
Set FD = Application.FileDialog(msoFileDialogFilePicker)
With FD
.InitialFileName = ThisWorkbook.Path & "\*.csv" 'adapter le répertoire
.Show
If .SelectedItems.Count > 0 Then fichier = .SelectedItems(1)
' Debug.Print fichier 'pour un test
"let" & Chr(13) & "" & Chr(10) & " Source = Csv.Document(File.Contents(" & fichier & "),[Delimiter="","", Columns=14, Encoding=65001, QuoteStyle=QuoteStyle.None])," & Chr(13) & "" & Chr(10) & " #""En-têtes promus"" = Table.PromoteHeaders(Source, [PromoteAllScalars=true])," & Chr(13) & "" & Chr(10) & " #""Type modifié"" = Table.TransformColumnTypes(#""En-têtes promus"",{{""CostType"", type text}, " & _
"ype logical}})" & Chr(13) & "" & Chr(10) & "in" & Chr(13) & "" & Chr(10) & " #""Type modifié"""j
Merci pour votre réponse.
Lorsque j’exécute le code j'ai l'erreur suivante :
La ligne suivante de monde code contient le mot "Source" également, c'est peut-être du à cela :
With ActiveSheet.ListObjects.Add(SourceType:=0, Source:= _
"OLEDB;Provider=Microsoft.Mashup.OleDb.1;Data Source=$Workbook$;Location=Customer_hotline;Extended Properties="""""
, Destination:=Range("$A$1")).QueryTable
.CommandType = xlCmdSql
.CommandText = Array("SELECT * FROM [Customer_hotline]")
.RowNumbers = False
.FillAdjacentFormulas = False
.PreserveFormatting = True
.RefreshOnFileOpen = False
.BackgroundQuery = True
.RefreshStyle = xlInsertDeleteCells
.SavePassword = False
.SaveData = True
.AdjustColumnWidth = True
.RefreshPeriod = 0
.PreserveColumnInfo = False
.ListObject.DisplayName = "Customer_hotline"
.Refresh BackgroundQuery:=FalseBonjour,
à quoi correspond la variable $Workbook$ ?
