VBA boucle For non fonctionnelle
Je sais pas ce qu'il se passe j'ai un gros problème, j'ai deux boucles For imbriquées l'une dans l'autre mais il n'incrémente jamais la boucle en j.
Mystère je comprends pas. Pour l'instant je vous joins pas les fichiers mais pouvez me dire si vous voyez un problème au niveau de ces boucles ?
D'avance merci.
Public Sub verif_DWR()
Dim derligPin_vr As Integer, derligPinC_mpa As Integer, derligPinA_mpa As Integer
Dim i As Long, j As Long, index As Long
Dim idx_cabinet_vr As Integer, idx_moduleID_vr As Integer, idx_pin_vr As Integer, idx_pinC_mpa As Integer, idx_pinA_mpa As Integer
Dim TEST As Boolean, TEST2 As Boolean
Dim Results As Worksheet, Pin As Worksheets, Feuil1 As Worksheets
Dim wb_vr As Workbook, wb_mpa As Workbook, tw As Workbook
UserForm1.Height = 352.2
UserForm1.Label5.Caption = "Vérification de la DWR"
On Error Resume Next
Set wb_vr = Workbooks.Open(UserForm1.TextBox1.Value)
Set wb_mpa = Workbooks.Open(UserForm1.TextBox2.Value)
Set tw = ThisWorkbook
idx_cabinet_vr = searchcolumn(wb_vr, "Results", "Cabinet")
idx_moduleID_vr = searchcolumn(wb_vr, "Results", "Module ID")
idx_pin_vr = searchcolumn(wb_vr, "Results", "PIN")
idx_pinC_mpa = searchcolumn(wb_mpa, "Pin", "Pin Connector")
idx_pinA_mpa = searchcolumn(wb_mpa, "Pin", "Pin address")
derligPin_vr = wb_vr.Worksheets("Results").Cells(Rows.Count, idx_pin_vr).End(xlUp).Row
derligPinC_mpa = wb_mpa.Worksheets("Pin").Cells(Rows.Count, idx_pinC_mpa).End(xlUp).Row
derligPinA_mpa = wb_mpa.Worksheets("Pin").Cells(Rows.Count, idx_pinA_mpa).End(xlUp).Row
index = 2
wb_mpa.Activate
wb_vr.Activate
For i = 2 To derligPin_vr
For j = 1 To derligPin_mpa
If wb_vr.Worksheets("Results").Cells(i, idx_pin_vr) <> "" Then
TEST = True
If wb_vr.Worksheets("Results").Cells(i, idx_pin_vr) = wb_mpa.Worksheets("Pin").Cells(j, idx_pinC_mpa) & wb_mpa.Worksheets("Pin").Cells(j, idx_pinA_mpa) Then
TEST2 = True
tw.Worksheets("Feuil1").Cells(index, 1).Value = wb_vr.Worksheets("Results").Cells(i, idx_pin_vr).Value
index = index + 1
MsgBox ("NOK")
Next j
UserForm1.Height = 367.2
Unload UserForm1
End SubBonjour,
tu l'as fait en pas à pas avec F8 pour affirmer que la 2nde boucle ne s'exécute pas ?
Si non, c'est comme qu'il faut faire si tu veux voir à quel endroit ça pèche.
eric
Bonjour eriiic,
Merci pour ta réponse, oui j'ai mis un arrêt sur next j, il y a uniquement next i qui s'incrémente mais la boucle en j il s'en fou
Je comprends pas pourtant j'en ai fais pas mal des boucles for jamais eu ce problème. Pour information, tous les idx et derlig ont bien une valeur.
Serait il possible que excel soit beugé ?
a revoir For j = 1 To derligPin_mpa
derligPin_mpa = 0
Maurice
Bonjour archer,
J'ai cherché pendant 2h pour une fichue lettre oubliée. Merci beaucoup. Je commençais à déprimer la lol
