Erreur d’exécution 91
J'ai fait un post précédemment dont j'ai trouvé la solution de mon problème quelques temps après.
Or là je bloque vraiment...
Le but est d'afficher le graph présent dans mon fichier actuellement ouvert sur Excel et de l'exporter sous forme d'image directement sur Word.
Voici mon code
Sub Export_Chart_Word()
'Name of an existing Word document, and the name the chart will have when exported.
Const stWordDocument As String = "C:\Users\xxxx\Documents\ChartReport.docx"
Const stChartName As String = "ChartReport.png"
'Word objects.
Dim wdApp As Word.Application
Dim wdDoc As Word.Document
Dim wdbmRange As Word.Range
'Excel objects.
Dim wbBook As Workbook
Dim wsSheet As Worksheet
Dim ChartObj As ChartObject
'Initialize the Excel objects.
Set wbBook = ThisWorkbook
Set wsSheet = wbBook.Worksheets("Feuil1")
Set ChartObj = wsSheet.ChartObjects("Graphique 1")
'Turn off screen updating.
'Export the chart to the current directory, using the specified name, and save the chart as a .gif
ChartObj.Chart.Export _
Filename:=wbBook.Path & "C:\Users\xxxx\Documents" & stChartName, _
FilterName:="PNG"
'Initialize the Word objects to the existing Word document and bookmark.
Set wdApp = New Word.Application
Set wdDoc = wdApp.Documents.Open(wbBook.Path & "C:\Users\xxxx\Documents" & stWordDocument)
Set wdbmRange = wdDoc.Bookmarks("ChartReport").Range
'If there is already an inline shape, that means the macro has been run before - clean up any artifacts.
On Error Resume Next
With wdDoc.InlineShapes(1)
.Select
.Delete
On Error GoTo 0
'Add the .gif file to the document at the bookmarked location,
'and ensure that it is saved inside the Word doc.
With wdbmRange
.Select
.InlineShapes.AddPicture _
LinkToFile:=False, _
savewithdocument:=True
'Save and close the Word document.
With wdDoc
.Save
.Close
'Quit Word.
wdApp.Quit
'Clear the variables.
Set wdbmRange = Nothing
Set wdDoc = Nothing
Set wdApp = Nothing
'Delete the temporary .gif file.
Kill wbBook.Path & "C:\Users\xxxx\Documents" & stChartName
On Error GoTo 0
MsgBox "Chart exported successfully to " & stWordDocument
Et le problème survient à cette ligne :
"Erreur d’exécution 91 Variable objet ou variable de bloc with non définie"
je pense que le problème vient de cette ligne
tu renseignes 2 fois le répertoire
Bonjour i20100,
Merci pour ta réponse,
Mais malheureusement ça n'a pas résolu mon problème, j'ai toujours la même erreur...
Avez-vous d'autre piste ?
salut,
t'as testé comme ca?
Set wdDoc = wdApp.Documents.Open(stWordDocument)
Oui ça fonctionne !!! Merci beaucoup.
J'aurais une seconde demande (sans abuser de votre temps), j'aimerais maintenant pouvoir récupérer de la même manière, tous les fichiers qui commence par le caractère "&" et qui ont la même couleur.
J'avais crée ce code :
For i = 1 To exl.Sheets.Count
spl = Split(exl.Sheets(i).Name, "&")
If exl.Sheets(i).Name <> spl(0) Then
j = 0
trouve = 0
Do While trouve = 0
j = j + 1
If j = 7 Then GoTo skyp
If exl.Sheets(i).Tab.ColorIndex = couleur(j) Then
trouve = 1
Loop
exl.Sheets(i).Select
exl.Sheets(i).ChartObjects(1).Activate 'Activate
nom_graphe = exl.ActiveChart.ChartTitle.text
Print #j, nom_graphe + " = " + exl.Sheets(i).Name
Mais je n'arrive pas à l'adapter à celui-là.
Merci encore.
il faut changer peut être cette ligne
comme ca
If exl.Sheets(i).Name = spl(0) Then
Je pense que ça va être plus compliqué que ça,
Dans l'idée, j'aimerais remplacer cette ligne :
Par une ligne permettant de récupérer toutes les figures ou graph, commençant par "&".
Merci pour votre aide.
