J'ai cette Macro qui ne fonctionne plus......
Seul le numéro de la ligne s'inscrit et ensuite plus rien .......
Merci pour votre aide (fichier ci joint)
Bonne journée
"Private Sub CommandButton1_Click()
'Sub ajout_action()
Dim val_pre As Integer
Dim val As Integer
val_pre = 0
val = 0
Worksheets("Actions").Activate
Columns("A").Cells.Find(What:="Chrono").Select
ActiveCell.Offset(1, 0).Select
While ActiveCell.Value <> ""
Wend
ActiveCell.Offset(-1, 0).Select
If ActiveCell.Value = "Chrono" Then
val_pre = 0
val_pre = ActiveCell.Value
val = val_pre + 1
ActiveCell.Value = val
ActiveCell.Offset(0, 1).Select
ActiveCell.Value = Date
'ActiveCell.Offset(0, 1).Select
'ActiveCell.Value = "Core Team Meeting"
ActiveCell.Offset(0, 5).Select
ActiveCell.Value = "Subject : "
ActiveCell.Value = "Action"
ActiveCell.Offset(0, 6).Select
ActiveCell.Value = "Open"
ActiveCell.Value = Date & " :"
ActiveCell.Offset(0, -10).Select
