J'ai un problème de code :
Dim Plage As Range
Dim Cel As Range
Set Plage = DefPlage(Worksheets("Compilation de Commande"), 4, 1)
i = 3
With Worksheets("Liste_des_Produits_sur_plats")
.Range("A3:H3").Value = Array("Date", "Heure", "N° de commande", "Client", "Commande en retard", "Articles", "Quantité", "Indication")
For Each Cel In Plage
If InStr(Cel.Value, "-Pt") <> 0 Then
i = i + 1
.Cells(i, 1).Value = Plage(Cel.Row - 3, 1).Value
.Cells(i, 2).Value = Plage(Cel.Row - 3, 1).Offset(, 1).Value
.Cells(i, 3).Value = Plage(Cel.Row - 3, 1).Offset(, 2).Value
.Cells(i, 4).Value = Plage(Cel.Row - 3, 1).Offset(, 3).Value
.Cells(i, 5).Value = Plage(Cel.Row - 3, 1).Offset(, 4).Value
.Cells(i, 6).Value = Plage(Cel.Row - 3, 1).Offset(, 5).Value
.Cells(i, 7).Value = Plage(Cel.Row - 3, 1).Offset(, 6).Value
.Cells(i, 8).Value = Plage(Cel.Row - 3, 1).Offset(, 7).Value
Next Cel
Worksheets("Compilation de Commande").Select
Pouvez-vous me dire ce qui ne va pas ?
En vous remerciant
