Problème fonction Indirectex
J'ai récupéré la macro Indirectex créé par Wilson So qui est une version de la fonction Indirect sur les classeurs fermés.
Code:
'Extended INDIRECT Function v1.0
'Copyright (c) 2009 Wilson So.
'E-mail: shwskm@yahoo.com.hk
'Credits:
'- Designed and written by Wilson So.
'- The 'CreateObject("Excel.Application")' trick was inspired by Harlan Grove's PULL function source code.
'This is an open source. You can freely redistribute and modify it, but please kindly give credit to the contributers.
'Please also kindly report any bugs/suggestions through e-mail or in the forums where I posted it.
'How to use:
'- Basically same as INDIRECT() in Excel - the same concept for the ref_text parameter.
'- To update the static memory for a particular reference,
'  type TRUE in the second parameter (just one of the IndirectEx() containing that reference)
'  and calculate it once.
'Features:
'- You can refer to the closed workbook data.
'- The retrieved closed workbook data will be stored in the static memory,
'  so in the next time, the closed workbook will not be opened again for fast retrieve.
'- A range instead of an array will be returned if the path is omitted in the ref_text,
'  so it still works fine if the user refers to an enormous array, e.g. "Sheet1!1:65536".
'- You can use it inside INDEX(), VLOOKUP(), MATCH() etc.
'- You can use it with OFFSET(), but only for opened workbook data.
'- The procedure will not blindly retrieve all the data as requested;
'  it will not retrieve data beyond the "Ctrl + End" cell, in order to keep the memory as small as possible.
'- #NUM! will be returned in case of lack of memory.
'- #REF! will be returned in case of a wrong path.
'- #VALUE! will be returned in case of other errors.
'Known issues:
'- Due to the use of SpecialCells(), #VALUE! will be returned if the worksheet for a closed workbook is protected.
Function IndirectEx(ref_text As String, Optional refresh_memory As Boolean = False) As Variant
    On Error GoTo ClearObject
    Dim RefName As String
    Dim SheetName As String
    Dim WBName As String
    Dim FolderName As String
    Dim vExcel As Object
    Dim vWB As Workbook
    Static dbOutput() As Variant
    Static dbKey() As String
    Static dbTotalOutput As Integer
    Dim dbIndex As Integer
    Dim UserEndRow As Long, UserEndCol As Integer
    Dim RealEndRow As Long, RealEndCol As Integer
    Dim EndRow As Long, EndCol As Integer
    Dim RangeHeight As Long, RangeWidth As Integer
    GetNames ref_text, RefName, SheetName, WBName, FolderName
    If dbTotalOutput = 0 Then
        ReDim dbOutput(1 To 1) As Variant
        ReDim dbKey(1 To 1) As String
    For i = 1 To dbTotalOutput
        If dbKey(i) = FolderName & WBName & "!" & SheetName & "!" & RefName Then
            dbIndex = i
    If dbIndex = 0 Or refresh_memory Then
        If dbIndex = 0 Then
            dbTotalOutput = dbTotalOutput + 1
            dbIndex = dbTotalOutput
            ReDim Preserve dbOutput(1 To dbTotalOutput) As Variant
            ReDim Preserve dbKey(1 To dbTotalOutput) As String
            dbKey(dbIndex) = FolderName & WBName & "!" & SheetName & "!" & RefName
        If FolderName = "" Then
            Set dbOutput(dbIndex) = Workbooks(WBName).Worksheets(SheetName).Range(RefName)
        ElseIf Dir(FolderName & WBName) <> "" Then
            Set vExcel = CreateObject("Excel.Application")
            Set vWB = vExcel.Workbooks.Open(FolderName & WBName)
            With vWB.Sheets(SheetName)
                UserEndRow = .Range(RefName).Row + .Range(RefName).Rows.count - 1
                UserEndCol = .Range(RefName).Column + .Range(RefName).Columns.count - 1
                RealEndRow = .Range("A1").SpecialCells(xlCellTypeLastCell).Row
                RealEndCol = .Range("A1").SpecialCells(xlCellTypeLastCell).Column
                EndRow = IIf(UserEndRow < RealEndRow, UserEndRow, RealEndRow)
                EndCol = IIf(UserEndCol < RealEndCol, UserEndCol, RealEndCol)
                RangeHeight = EndRow - .Range(RefName).Row + 1
                RangeWidth = EndCol - .Range(RefName).Column + 1
                On Error Resume Next
                dbOutput(dbIndex) = .Range(RefName).Resize(RangeHeight, RangeWidth).Value
                If Err.Number <> 0 Then
                    IndirectEx = CVErr(xlErrNum)
                    GoTo ClearObject
            vWB.Close False
            vExcel.Quit
            Set vExcel = Nothing
            IndirectEx = CVErr(xlErrRef)
            Exit Function
    If TypeOf dbOutput(dbIndex) Is Range Then
        Set IndirectEx = dbOutput(dbIndex)
    Exit Function
ClearObject:
    If Not (vExcel Is Nothing) Then
        vWB.Close False
        vExcel.Quit
End Function
Private Sub GetNames(ByVal ref_text As String, ByRef RefName As String, ByRef SheetName As String, ByRef WBName As String, ByRef FolderName As String)
    Dim P_e As Integer
    Dim P_b1 As Integer
    Dim P_b2 As Integer
    Dim P_s As Integer
    P_e = InStr(1, ref_text, "!")
    P_b1 = InStr(1, ref_text, "[")
    P_b2 = InStr(1, ref_text, "]")
    P_s = InStr(1, ref_text, ":\")
    If P_e = 0 Then
        RefName = ref_text
        RefName = Right$(ref_text, Len(ref_text) - P_e)
    RefName = Replace$(RefName, "$", "")
    If P_e = 0 Then
        SheetName = Application.Caller.Parent.Name
    ElseIf P_b1 = 0 Then
        SheetName = Left$(ref_text, P_e - 1)
        SheetName = Mid$(ref_text, P_b2 + 1, P_e - P_b2 - 1)
    SheetName = Replace$(SheetName, "'", "")
    If P_b1 = 0 Then
        WBName = Application.Caller.Parent.Parent.Name
        WBName = Mid$(ref_text, P_b1 + 1, P_b2 - P_b1 - 1)
    If P_s = 0 Then
        FolderName = ""
        FolderName = Left$(ref_text, P_b1 - 1)
    If Left$(FolderName, 1) = "'" Then FolderName = Right$(FolderName, Len(FolderName) - 1)
Je lis un peu partout sur des forums que ça fonctionne très bien mais que c'est un peu lent, mais pour moi ça ne fonctionne pas du tout, ça me renvoie toujours 0.
Pourtant dans la fenêtre de la fonction je vois bien la valeur que j'attends au niveau de la référence du texte(ref_text) mais mon résultat final est 0.
Je ne sais pas quelle valeur mettre dans refresh_memory (0,1,etc...). Est-ce que c'est dû à la valeur renseignée dans cette case ou alors à ma version d'Excel (2010)?
j'ai fais le test
=IndirectEx("'C:\Users\isabelle\Documents\[test.xlsx]Feuil1'!$A$1";1)
le résultat est 0
et le test
=IndirectEx("'C:\Users\isabelle\Documents\[test.xlsx]Feuil1'!$A$1";0)
le résultat est bon
Rechercher des sujets similaires à "probleme fonction indirectex"
