Bonjour Firstname...
OK compris...
Du coup, nouvelle version de la proc d'export :
Sub ExportCSV()
Const cSep = ","
Dim plage As Range
Dim oRow As Range, oCell As Range
Dim oTS As Object, oFS As Object
Dim sFilename As String
Dim sBuffer As String
Dim oSheet As Worksheet
Dim lLastrow As Long
Dim lFirstCol As Long, lLastCol As Long
Dim aValues() As String, sValue As String, i As Integer
Set oSheet = ActiveSheet
lLastrow = oSheet.UsedRange.Rows.Count
lFirstCol = Letter2Number("T")
lLastCol = Letter2Number("AQ")
ReDim aValues((lLastCol - lFirstCol) + 1)
With oSheet
Set plage = .Range(.Cells(1, lFirstCol), .Cells(lLastrow, lLastCol))
sFilename = ThisWorkbook.Path & "\" & "ExportToCRM_" & Format(Now(), "yyyymmdd-HHMM") & ".csv"
Set oFS = CreateObject("Scripting.FileSystemObject")
Set oTS = oFS.CreateTextFile(sFilename, False)
For Each oRow In plage.Rows
For i = 1 To oRow.Columns.Count
Set oCell = oRow.Cells(1, i)
sValue = Replace(oCell.Value, ",", "")
If Len(oCell.NumberFormat) > 0 Then
sValue = Format(sValue, oCell.NumberFormat)
If sValue = "0" Then
sValue = ""
aValues(i - 1) = sValue
sBuffer = Join(aValues(), cSep)
oTS.WriteLine sBuffer
oTS.Close
Set oTS = Nothing
Set oFS = Nothing
Function Letter2Number(zLetter As String) As Long
'SOURCE: www.TheSpreadsheetGuru.com/the-code-vault
Letter2Number = Range(zLetter & 1).Column
End Function
