J'aimerai rajouter dans la macro la fonction =RECHERCHEV(D4;CENTRE!A:B;2;FAUX) en cellule D7 mais je ne sais pas modifier ma macro. Merci pour votre aide.
Kassou
Public Sub Copy_data()
'Déclaration des variables
Dim wb As Workbook
Dim wsData As Worksheet, wsTable As Worksheet
Dim lo As ListObject
Dim Cell As Range
'Initialisaton des variables
Set wb = ActiveWorkbook
Set wsData = wb.Worksheets("SAISIE DU JOUR")
Set wsTable = wb.Worksheets("RECAP")
Set lo = wsTable.ListObjects("T_RECAP")
'Détermination de la cellule pour restitution des données
'de Saisie Du Jour dans Recap (T_RECAP)
With lo
If .InsertRowRange Is Nothing Then
Set Cell = .HeaderRowRange.Cells(1).Offset(.ListRows.Count + 1)
Set Cell = .InsertRowRange.Cells(1)
'Restitution des données Saisie du jour dans T_RECAP
With Cell
.Value = wsData.Cells(5, 6).Value 'Date : Cellule F5
.Offset(, 1).Value = wsData.Cells(2, 4).Value 'V/T : Cellule D2
.Offset(, 2).Value = wsData.Cells(4, 4).Value
.Offset(, 3).Value = wsData.Cells(5, 4).Value
.Offset(, 4).Value = wsData.Cells(7, 4).Value
.Offset(, 5).Value = wsData.Cells(9, 4).Value
.Offset(, 6).Value = wsData.Cells(11, 4).Value
.Offset(, 7).Value = wsData.Cells(13, 4).Value
.Offset(, 8).Value = wsData.Cells(14, 4).Value
.Offset(, 9).Value = wsData.Cells(15, 4).Value
.Offset(, 10).Value = wsData.Cells(16, 4).Value
.Offset(, 11).Value = wsData.Cells(18, 4).Value
.Offset(, 12).Value = wsData.Cells(20, 4).Value
.Offset(, 13).Value = wsData.Cells(22, 4).Value
.Offset(, 14).Value = wsData.Cells(24, 4).Value
.Offset(, 15).Value = wsData.Cells(25, 4).Value
.Offset(, 16).Value = wsData.Cells(27, 4).Value 'Prêt : Cellule D27
.Offset(, 17).Value = wsData.Cells(29, 4).Value 'SCE repairs : Cellule D29
'Tri du tableau T_RECAP
With lo
.Sort.SortFields.Add .ListColumns(1).DataBodyRange, xlSortOnValues, xlDescending
.Sort.Apply
.Sort.SortFields.Clear
'RAZ cellules Saisie du Jour
wsData.Range("D2,D4,D5,D7,D9,D11,D13,D14,D15,D16,D18,D20,D22,D24,D25,D27,D29").ClearContents
