Formater les lignes d'un tableau en fonction d'une cellule
Bonjour a tous,
Tout d'abord, merci de votre précieuse aide et conseille.
Voila, je veux formater la valeur des ligne de mon tableau en fonction de la valeur d'une cellule. Pour cela, j'utilise un bouton qui va executer
mon code et formater les cellules. Voir mon code ci-dessous.
Const str_NOM_DE_LAFEUILLE As String = "Échéancier"
Const str_LAPLAGE_DE_REFERENCE As String = "C11"
Const str_NOM_ENTETEPLAGE_AFORMATER As String = "DATE D’ÉCHÉANCE"
Const str_NOM_TABLEAU_AFORMATER As String = "ÉchéancierPaiement"
Const int_LigneDeRefe_Formater As Integer = 11
Const int_ColonneDeRef_Formater As Integer = 3
Dim rng_PlageAReferencer As Range
Sub formaterTabSelonDate(ByRef str_NOMFEUILL_AFORMATER As String, _
ByRef rng_PalgeAFormater As Range, _
ByRef str_NOM_ENTETEPLAGE_AFORMATER As String, _
ByRef int_LigneDeRefe_Formater As Integer, _
ByRef int_ColonneDeRef_Formater As Integer, _
ByRef str_NOM_TABLEAU_AFORMATER As String)
'Variable objet
Dim Cellule As Range
Dim NbrDeColonne As Integer
'Variable
Dim d_CETTE_ANNEE As Variant
Dim d_CE_MOIS As Variant
'***** Initialiser les variables *****'
NbrDeColonne = Cells(int_LigneDeRefe_Formater, int_ColonneDeRef_Formater).End(xlToRight).Column
d_CETTE_ANNEE = Year(Now)
d_CE_MOIS = Month(Now)
If Cells(int_LigneDeRefe_Formater, rng_PalgeAFormater.Column).Value = str_NOM_ENTETEPLAGE_AFORMATER Then
For Each Cellule In Sheets(str_NOMFEUILL_AFORMATER).Range(str_NOM_TABLEAU_AFORMATER)
If (Year(rng_PalgeAFormater.Value) = d_CETTE_ANNEE) Then
If Month(rng_PalgeAFormater.Value) < d_CE_MOIS Then
Range(Cells(rng_PalgeAFormater.Row, int_ColonneDeRef_Formater), _
Cells(rng_PalgeAFormater.Row, NbrDeColonne)).Interior.Color = 192 ' rouge
Cells(rng_PalgeAFormater.Row, NbrDeColonne)).Font.Color = vbWhite 'police_MOIS_PRECEDANT
Exit For
ElseIf (Month(rng_PalgeAFormater.Value) = d_CE_MOIS) Then
Cells(rng_PalgeAFormater.Row, NbrDeColonne)).Interior.Color = 65535 'jaune
Cells(rng_PalgeAFormater.Row, NbrDeColonne)).Font.Color = vbBlack 'police_CETTEANNEE_CEMOIS
Exit For
ElseIf (Year(rng_PalgeAFormater.Value) < d_CETTE_ANNEE) Then
Cells(rng_PalgeAFormater.Row, NbrDeColonne)).Interior.Color = vbBlack ' vbBlack
Exit For
Next Cellule
Exit Sub
End SubOr, au débogage l'erreur de compilation suivante a été générer: Next sans For.
Pourriez-vous me dire ce qui ne fonctionne pas avec mon code. Merci
Bonjour jlkKaty07,
essaye ceci :
'Variable objet
'Variable
If Cells(int_LigneDeRefe_Formater, rng_PalgeAFormater.Column).Value <> str_NOM_ENTETEPLAGE_AFORMATER Then Exit Sub
Exit For
Exit For
Exit For
Next Cellule
End Subdhany
Merci dhany,
J'ai modifier le code ainsi selon ton conseil
Const str_LAPLAGE_DE_REFERENCE As String = "C12"
Const int_ColonneDeRef_Formater As Integer = 2
Private Sub cmd_Rafraichir_Click()
' 'Initialiser la plage
Set rng_PlageAReferencer = ThisWorkbook.Sheets(str_NOM_DE_LAFEUILLE).Range(str_LAPLAGE_DE_REFERENCE)
Call mod_0_Formatage.formaterTabSelonDate(str_NOM_DE_LAFEUILLE, _
rng_PlageAReferencer, _
str_NOM_ENTETEPLAGE_AFORMATER, _
int_LigneDeRefe_Formater, _
int_ColonneDeRef_Formater, _
'Variable objet
'Variable
Exit For
Exit For
Exit For
Next Cellule
End Subj'ai toujours un problème. Mon but est de parcourir la table en entier et faire la mise en forme de chaque ligne du tableau
dépendamment de la date d'échéance de chaque cellule de la colonne '"Date échéance". En pièce jointe un screeshot de mon tableau.
Je veux que tout les lignes du tableau soit traité.
Merci de votre aide
