Data function
Good afternoon,
Please, can you help me with this problem?
In the attachment, in column E I use a search function (= INDEX (Sheet2! $ E $ 2: $ E $ 32; MAX (INDEX ((Sheet2! $ A $ 2: $ A $ 32 = C2) * (Sheet2! $ D $ 2: $ D $ 32 = D2) * ROW (Sheet2! $ D $ 2: $ D $ 32) -FILA (Sheet2! $ D $ 1);))).
I would like to load this function in that column E with a macro.
How should the programming of the macro be?
Greetings,
Ferdinan
30data-function.xlsx (34.87 KB)
Hello,
The best for you is to create a Name with this Formula
Select the Cells "E2" and copy the Formula (Select it in the Formula Bar)
In the ribbon Open the Name Manager
Add a new name (By exemple SUBSTFRM) and in the ReferTo area put the Formula
Send Ok
Now you can use "= SUBSTFRM" instead of the original function.
Then in VBA you can write :
Range("E2:E10000").Formula = "=SUBSTFRM"
That's enough !
See the exemple...
29data-function-vg.xlsx (133.71 KB)
Hello,
I have a file in which I have many functions and the file goes a little slow.
Which of these methods is the most efficient, so that it goes faster?
Regards,
Ferdinan
I'm going to try both methods and see which is the most efficient?
Thank you very much for your help.
Regards,
Ferdinan
Hello,
Realy they are the same.
Use the one that seems the easiest to program.
Hello,
thank you very much for your attention
Regards,
Ferdinan
Search for threads similar to "data function"
