Salut le forum
Amadéus, j'ai adapté ta macro de Soft pour la question.
'Code initial Soft Excel Pratique
Sub Rempli()
Dim Temp As Integer, Existe As Boolean
Dim I As Integer, J As Integer
Dim Tableau(100) As Integer, RDest As Range
Set RDest = ActiveSheet.Range("A1:A100")
Randomize
For I = 1 To 100
Existe = True
While Existe
Temp = Int(100 * Rnd + 1)
For J = 1 To 100
If Temp = Tableau(J) Then
Existe = True
Exit For
Existe = False
Next J
Wend
Tableau(I) = Temp
Next I
For I = 1 To 100
Select Case Tableau(I)
Case 1 To 45
J = 1
Case 46 To 71
J = 2
Case 72 To 87
J = 3
Case 88 To 96
J = 4
Case Else
J = 5
End Select
RDest(I).Value = J
Next I
Mytå
