VBA - Difficulté à tourner
Pour le travail j'ai du écrire un macro me facilitant la vie, malheureusement, elle met énormément de temps à tourner..
Pourtant j'en ai de bien plus grosse qui tournent 10 fois plus vite.
Sub ATA()
Dim colonneEntree As Integer 'Colonne ATA'
Dim colonneSortie As Integer 'Colonne ATA + description'
Dim derligne&
colonneEntree = 14
colonneSortie = 15
derligne = Sheets("OI Base").Range("A" & Rows.Count).End(xlUp).Row 'Definition de la dernière ligne de la colonne A'
    For i = 2 To derligne
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "5" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 5 TILE LIMITS / MAINTENANCE CHECKS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "6" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 6 DIMENSIONS AND AREAS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "7" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 7 LIFTING AND SHORING"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "8" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 8 LEVELING AND WEIGHING"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "9" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 9 TOWING AND TAXING"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "10" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 10 PARKING, MOORING, STORAGE AND TURN TO SERVICE"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "11" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 11 PLACARDS AND MARKINGS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "12" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 12 SERVICING - ROUTINE MAINTENANCE"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "14" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 14 HARDWARE"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "18" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 18 HELICOPTER VIBRATION"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "20" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 20 STANDARD PRACTICES - AIRFRAME"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "21" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 21 AIR CONDITIONING AND PRESSURIZATION"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "22" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 22 AUTOFLIGHT"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "23" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 23 COMMUNICATIONS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "24" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 24 ELECTRICAL POWER"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "25" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 25 EQUIPMENT / FURNISHINGS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "26" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 26 FIRE PROTECTION"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "27" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 27 FLIGHT CONTROLS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "28" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 28 FUEL"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "29" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 29 HYDRAULIC POWER"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "30" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 30 ICE AND RAIN PROTECTION"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "31" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 31 INDICATING / RECORDING SYSTEM"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "32" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 32 LANDING GEAR"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "33" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 33 LIGHTS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "34" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 34 NAVIGATION"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "35" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 35 OXYGEN"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "36" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 36 PNEUMATIC"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "37" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 37 VACUUM"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "38" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 38 WATER / WASTE"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "42" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 42 INTEGRATED MODULAR AVIONICS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "44" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 44 CABIN SYSTEM"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "45" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 45 DIAGNOSTIC AND MAINTENANCE SYSTEM"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "46" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 46 INFORMATION SYSTEMS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "47" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 47 NITROGEN GENERATION SYSTEM"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "48" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 48 IN FLIGHT FUEL DISPENSING"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "49" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 49 AIRBORNE AUXILIARY POWER"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "50" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 50 CARGO AND ACCESSORY COMPARTMENTS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "51" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 51 STANDARD PRACTICES AND STRUCTURES - GENERAL"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "52" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 52 DOORS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "53" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 53 FUSELAGE"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "54" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 54 NACELLES / PYLONS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "55" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 55 STABILIZERS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "56" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 56 WINDOWS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "57" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 57 WINGS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "60" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 60 STANDARD PRACTICES"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "61" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 61 PROPELLES"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "62" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 62 ROTORS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "63" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 63 ROTOR DRIVE SUSTEM"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "64" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 64 TAIL ROTOR"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "65" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 65 TAIL ROTOR DRIVE SYSTEM"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "66" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 66 BLADES & PYLONS FOLDING DEVICE"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "67" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 67 ROTOR FLIGHT CONTROLS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "70" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 70 STANDARS PRACTICES - ENGINES"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "71" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 71 POWER PLANT"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "72" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 72 ENGINE"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "73" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 73 ENGINE - FUEL AND CONTROL"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "74" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 74 IGNITION"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "75" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 75 AIR"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "76" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 76 ENGINE CONTROLES"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "77" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 77 ENGINE INDICATION"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "78" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 78 EXHAUST & THRUST REVERSER"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "79" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 79 OIL"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "80" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 80 STARTING"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "81" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 81 TURBINES (RECIPROCATING ENGINES)"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "82" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 82 ENGINE WATER INJECTION"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "83" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 83 ACCESSORY GEARBOXES"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "84" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 84 PROPULSION AUGMENTATION"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "89" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 89 FLIGHT TEST INSTALLATION"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "91" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 91 CHARTS"
            If Sheets("OI Base").Cells(i, colonneEntree).Value = "92" Then
                Sheets("OI Base").Cells(i, colonneSortie).Value = "ATA 92 ELECTRICAL AND ELECTRONIC COMMON INSTALLATION"
Pourriez-vous me donner quelques conseils si vous pouvez.
Merci d'avance,
FloBru
Pourquoi faire ça par macro et non pas par une simple formule Recherchev() qui récupère la valeur dans une table ?
eric
Des conseils pour que ta macro aille beaucoup plus vite ... il en existe beaucoup ...
Tu peux commencer par insérer comme premiére ligne :
Application.Calculation = xlCalculationManual
et finir avec comme dernière ligne :
Application.Calculation = xlCalculationAutomatic
En espèrant que cela t'aide ...
Si tu ne veux pas opérer une recherche par formule, comme conseillé par Eric :
Sub ATA()
    Dim Tata() As String, Sata() As String, dln&, i&
    'On suppose que l'on a une table de recherche nommée TablAta à 2 colonnes...
    'Sinon il faudra adapter selon dont on dispose pour constituer tableau...
    With [TablAta]
        ReDim Tata(.Cells(.Rows.Count, 1))
        For i = 1 To Rows.Count
            Tata(.Cells(i, 1)) = .Cells(i, 2)
    With Worksheets("OI Base")
        dln = .Cells(.Rows.Count, 1).End(xlUp).Row
        ReDim Sata(2 To dln, 0)
        For i = 2 To dln
            Sata(i, 0) = Tata(.Cells(i, 14))
        .Cells(2, 15).Resize(dln - 1).Value = Sata
Outre l'adaptation éventuelle pour constituer tableau Tata, il y aura peut-être à convertir les valeurs cherchées (col. Entrée et col. 1 de la table de recherche) en valeurs numériques s'il s'agit de valeurs textes...
NB- J'ai toujours la plus grande méfiance et de nombreuses réserves à travailler avec des nombres entre guillemets, on est à la merci de conversions automatiques non maîtrisées... Il est toujours préférable de travailler explicitement avec des nombres...
@Eriiic, je faisais avant appel à un tableau et une recherchev() mais mon document étant accessible et bloqué à beaucoup de monde je me dois de faire des boutons e mises à jour sur une page d'accueil pour que le fichier tourne même en mon absence.
Et ca me permet aussi de supprimer des colonnes de paramètres.
@james007, en effet cela va plus vite merci!
@MFerrand, ta réponse m'aide aussi beaucoup, je vais m'en servir pour un autre tableau mais si je comprends bien il me faut garder des colonnes paramètres qui encombrent énormément mon tableau.
Un énorme merci à vous ca m'aide beaucoup!
FloBru
Merci ... pour tous tes remerciements ...
Bonne Continuation ...
Bonjour, Salut à tous !
Si tu entends par là la table de recherche, telle que l'a indiquée Eric, c'est en effet le moyen le plus simple. Tu la places sur une feuille annexe que tu masques, et elle ne devrait guère être gênante...
On peut bien sûr faire sans, mais c'est un peu plus compliqué et cela accroît les risques d'erreurs. Alors qu'une telle table peut facilement être mise à jour et contrôlée...
Rechercher des sujets similaires à "vba difficulte tourner"
