Need with Macro very ly! Will be so grateful
Hello,
If someone can help, I will be so grateful as I have been striving 2 days with it.
So, I have a source data( Tab "To go") with which I would like to run a macro. So, I have already recorded my macro(see macro22, macro 11, or macro 5 as I have tried several times).
In my macro I have filtered the data, and selected only one column to make a pivot. The final step I want this pivot to be directly printng.
However when I run the macro, the final pivot is not coming how it should be (It is only Total coming), and I don't have any idea what can be n issue.
Please could you see a file and help me, otherwise I will die )
I cannot download the file directly to here, so could you please contact me katia.dmitrenko@gmail.com, and I will send you the file.
Hello,
Understand you cannot attach your workbook ... for confidential reasons ...
However, the one thing you could do is insert the code you have created ...
It might be that ... just by looking at your macro ... a solution might pop up ....
Many thanks for your reply!
Of course I can paste here the code.
Sub macro11()
' macro11 Macro
Rows("1:1").Select
Range("H1").Activate
Selection.Insert Shift:=xlDown, CopyOrigin:=xlFormatFromLeftOrAbove
Range("H1").Select
ActiveCell.FormulaR1C1 = "Column1"
Range("H1").Select
Selection.AutoFill Destination:=Range("H1:M1"), Type:=xlFillDefault
Range("H1:M1").Select
Selection.AutoFill Destination:=Range("H1:N1"), Type:=xlFillDefault
Range("H1:N1").Select
Columns("M:M").Select
Selection.AutoFilter
ActiveSheet.Range("$M$1:$M$159").AutoFilter Field:=1, Criteria1:= _
"CONTENT - [File has been sent to BT]"
Columns("N:N").Select
Selection.TextToColumns Destination:=Range("O1"), DataType:=xlFixedWidth, _
FieldInfo:=Array(Array(0, 1), Array(7, 1), Array(9, 1), Array(15, 1), Array(63, 1), _
Array(73, 1), Array(187, 1), Array(195, 1)), TrailingMinusNumbers:=True
Columns("P:S").Select
Selection.Delete Shift:=xlToLeft
Range("N1").Select
Selection.AutoFill Destination:=Range("N1:T1"), Type:=xlFillDefault
Range("N1:T1").Select
Range("T1").Select
Selection.ClearContents
Range("S1").Select
Columns("Q:Q").Select
Selection.Replace What:="=-", Replacement:="", LookAt:=xlPart, _
SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _
ReplaceFormat:=False
ActiveWindow.ScrollRow = 3
ActiveWindow.ScrollRow = 39
ActiveWindow.ScrollRow = 41
ActiveWindow.ScrollRow = 43
ActiveWindow.ScrollRow = 44
ActiveWindow.ScrollRow = 46
ActiveWindow.ScrollRow = 48
ActiveWindow.ScrollRow = 50
ActiveWindow.ScrollRow = 52
ActiveWindow.ScrollRow = 54
ActiveWindow.ScrollRow = 57
ActiveWindow.ScrollRow = 58
ActiveWindow.ScrollRow = 60
ActiveWindow.ScrollRow = 62
ActiveWindow.ScrollRow = 64
ActiveWindow.ScrollRow = 67
ActiveWindow.ScrollRow = 68
ActiveWindow.ScrollRow = 71
ActiveWindow.ScrollRow = 72
ActiveWindow.ScrollRow = 74
ActiveWindow.ScrollRow = 77
ActiveWindow.ScrollRow = 78
ActiveWindow.ScrollRow = 82
ActiveWindow.ScrollRow = 84
ActiveWindow.ScrollRow = 86
ActiveWindow.ScrollRow = 88
ActiveWindow.ScrollRow = 90
ActiveWindow.ScrollRow = 93
ActiveWindow.ScrollRow = 94
ActiveWindow.ScrollRow = 96
ActiveWindow.ScrollRow = 98
ActiveWindow.ScrollRow = 100
ActiveWindow.ScrollRow = 103
ActiveWindow.ScrollRow = 104
ActiveWindow.ScrollRow = 106
ActiveWindow.ScrollRow = 108
ActiveWindow.ScrollRow = 110
Sheets.Add
ActiveWorkbook.PivotCaches.Create(SourceType:=xlDatabase, SourceData:= _
"To go!R1C17:R1048576C17", Version:=6).CreatePivotTable TableDestination:= _
"Feuil1!R3C1", TableName:="Tableau croisé dynamique2", DefaultVersion:=6
Sheets("Feuil1").Select
Cells(3, 1).Select
With ActiveSheet.PivotTables("Tableau croisé dynamique2").PivotFields( _
"Column10")
.Orientation = xlRowField
.Position = 1
ActiveSheet.PivotTables("Tableau croisé dynamique2").AddDataField ActiveSheet. _
PivotTables("Tableau croisé dynamique2").PivotFields("Column10"), _
"Nombre de Column10", xlCount
Range("A3:B10").Select
Selection.Borders(xlDiagonalDown).LineStyle = xlNone
Selection.Borders(xlDiagonalUp).LineStyle = xlNone
With Selection.Borders(xlEdgeLeft)
.LineStyle = xlContinuous
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlMedium
With Selection.Borders(xlEdgeTop)
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlMedium
With Selection.Borders(xlEdgeBottom)
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlMedium
With Selection.Borders(xlEdgeRight)
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlMedium
Selection.Borders(xlInsideVertical).LineStyle = xlNone
Selection.Borders(xlInsideHorizontal).LineStyle = xlNone
Range("B7").Select
Selection.ShowDetail = True
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
With Selection.Borders(xlInsideVertical)
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
With Selection.Borders(xlInsideHorizontal)
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
Range("A3").Select
"Column10")
.PivotItems("(blank)").Visible = False
Range("A3").Select
ActiveSheet.PivotTables("Tableau croisé dynamique2").CompactLayoutRowHeader = _
"Numéro de lot"
Range("B3").Select
ActiveSheet.PivotTables("Tableau croisé dynamique2").DataPivotField.PivotItems( _
"Nombre de Column10").Caption = "Total"
Range("A3:B9").Select
ActiveWindow.SelectedSheets.PrintOut Copies:=1, Collate:=True, _
IgnorePrintAreas:=False
Thanks again and waiting for your respond.
Hello,
Your macro looks like being the result of the Macro Recorder ...
In addition, you have performed many actions which are not truly related to your business objective ...
How Urgent is your situation ???
James007 a écrit :
Hello,
Yes, I was recordng actions, as I don't know visual basic of course
Honestly my main purpose is to create macro which will do for me the following: select data from a big data extract and after make a pivot from it, and then print that pivot.
Looking easy but indeed I can not find the problem with that pivot creation honestly:(
Hello,
can you send us a file ?
We need additional information to help you.
Jean-Eric a écrit :
Hello,
Many thanks for your response!
Here you can see the file, the macro which is the last and the most successful is named "Macro".
The first Worksheet is the data extract that I have and second one is the one where I created the macro.
Waiting for your reply, nd thanks again. Please, let me know if you have any other questions.
42extract-macro.xlsm (79.39 KB)
Search for threads similar to "need macro very grateful"
