Variable dans filtre where
c
voila comment utiliser une variable pour modifier dans where
je m'explique
choixx est different a la demande , donc cela peut etre un filtre jour, mois, seamine etc..
Sub export()
ActiveSheet.Columns("D:D").Select
Selection.NumberFormat = "dd/mm/yyyy"
choixx = "Month(Date_Saisie) = '6'"
With ActiveSheet.ListObjects.Add(SourceType:=0, Source:=Array(Array( _
"ODBC;DSN=MS Access Database;DBQ=C:\Users\geraldine\Documents\controleso.mdb;DefaultDir=C:\Users\geraldine\Documents;DriverId=25;FIL=" _
), Array("MS Access;MaxBufferSize=2048;PageTimeout=5;")), _
Destination:=Range("$A$1")).QueryTable
'.CommandType = 0
.CommandText = Array( _
"SELECT Listes.DO_Piece, Listes.RP_Code, Listes.AR_ref, Listes.Date_Saisie, Listes.DL_Qte, Listes.Initiales" & Chr(13) & "" & Chr(10) & "FROM `C:\Users\geraldine\Documents\controleso.mdb`.Listes Listes" & Chr(13) & "" & Chr(10) & "WHERE (Listes.RP_Code='021" _
, "COFEMBA') AND (Listes.Initiales='SOFC0105') AND choixx ")
.RowNumbers = False
.FillAdjacentFormulas = False
.PreserveFormatting = True
.RefreshOnFileOpen = False
.BackgroundQuery = True
.RefreshStyle = xlInsertDeleteCells
.SavePassword = False
.SaveData = True
.AdjustColumnWidth = True
.RefreshPeriod = 0
.PreserveColumnInfo = True
.Refresh BackgroundQuery:=False
End Submerdi d'avance
bonjour,
essaie ceci
, "COFEMBA') AND (Listes.Initiales='SOFC0105') AND " & choixx )c
j'ai une erreur de syntaxe
Sub Macro5()
Cells.Select
Selection.Clear
choixx = "Listes.Initiales='SOFC0105'"
), Array("MS Access;MaxBufferSize=2048;PageTimeout=5;")), Destination:=Range("$A$1")).QueryTable
.CommandText = "SELECT Listes.DO_Piece, Listes.RP_Code, Listes.AR_ref, Listes.Date_Saisie, Listes.DL_Qte, Listes.Initiales" & Chr(13) & "" & Chr(10) & "FROM `C:\Users\geraldine\Documents\controleso.mdb`.Listes Listes" & Chr(13) & "" & Chr(10) & "WHERE (Listes.RP_Code='021COFEMBA') AND & choixx )"
.RowNumbers = False
.SaveData = True
.RefreshPeriod = 0
End Subje poste ma macro
.CommandText = _
, "COFEMBA') AND (Listes.Initiales='SOFC0105') AND " & choixx c
merci je vais pouvoir avancer maintenant avec mes dates du moins j 'espère
