Excel se ferme avec macro If Not
B
Avant tout je début en VBA, et n'ai pas trouvé le pourquoi du comment en recherchant.
J'utilise ce code que j'ai adapté pour modifier la valeur de certaines cellules via vba.
Mais le code fait planter Excel, depuis l'ajout des dernières modifications:
Ajout des If Not et plusieurs Range en KeyCells.
Auriez vous une piste?
Sub resetDataPhone()
If [C15].Value = "-" Then
[C17].Value = " "
If [D15].Value = "-" Then
[D17].Value = " "
If [E15].Value = "-" Then
[E17].Value = " "
If [B22].Value = "-" Then
[B24].Value = " "
If [C22].Value = "-" Then
[C24].Value = " "
If [D22].Value = "-" Then
[D24].Value = " "
If [E22].Value = "-" Then
[E24].Value = " "
If [D9].Value = "-" Then
[E9].Value = " "
[E10].Value = " "
[E11].Value = " "
[E12].Value = " "
If Not [C16].Value Like "*Phone*" Then
[C19].Value = " "
If Not [D16].Value Like "*Phone*" Then
[D19].Value = " "
If Not [E16].Value Like "*Phone*" Then
[E19].Value = " "
If Not [B23].Value Like "*Phone*" Then
[B26].Value = " "
If Not [C23].Value Like "*Phone*" Then
[C26].Value = " "
If Not [D23].Value Like "*Phone*" Then
[D26].Value = " "
If Not [E23].Value Like "*Phone*" Then
[E26].Value = " "
Dim KeyCells As Range
' The variable KeyCells contains the cells that will
' cause an alert when they are changed.
Set KeyCells = Range("C15,C17,D9,D15,D17,E15,E17,B22,B24,C22,C24,D22,D24,E22,E24")
If Not Application.Intersect(KeyCells, Range(Target.Address)) _
Is Nothing Then
resetDataPhone
End SubBonjour,
essaie ainsi :
If Not Application.Intersect(KeyCells, Range(Target.Address)) Is Nothing Then
resetDataPhone
End SubB
Cela fonctionne
Un tout grand merci
