S'il vous plait j'ai besoin de votre aide, j'ai un algorithme qui calcule une colonne mais il m'affiche le résulté sous forme :
" 26,85050798
24,38316401
24,38316401
24,38316401
Par contre je voulais juste 2 chiffre après la virgule, voila le code que j'ai utilisé:
Sub calculScrap1()
Dim ws As Worksheet
Const SourceColumn As String = "AH"
Const DestColumn As String = "AK"
Const TotalCell As String = "AJ6" 'total defect of all defects
Const StartRow As Long = 9
Dim EndRow As Long, i As Long
Dim VisRng As Range, c As Range
On Error Resume Next
Set ws = Sheet4
With ws
EndRow = .Range("AH" & StartRow).End(xlDown).Row '<-- get last row with data in Column G
' set visible range to only filtered cells in Column G
Set VisRng = .Range(Range(SourceColumn & StartRow), Range(SourceColumn & EndRow)).SpecialCells(xlCellTypeVisible)
.Range(TotalCell).Formula = WorksheetFunction.sum(VisRng) '<-- re-calculate Total defects according to visible range
For Each c In VisRng
.Range(DestColumn & c.Row).Formula = "=(" & SourceColumn & c.Row & "/" & TotalCell & ")*100"
Next c
On Error GoTo 0
