Bug dans une macro
j'ai une macro qui me sert à masquer des feuilles, et elle ne marche plus du tout, je ne sais pas d'où vient l'erreur
lien effacé
En gros les onglets P5 des feuilles mensuelles ont toutes la même valeur automatiquement, et la valeur définie masque automatiquement certaines feuilles mensuelles
Voici le code
Private Sub Workbook_SheetChange(ByVal Sh As Object, ByVal Target As Range)
Dim AD As String
    Select Case Sh.Name
        Case "Stats annuelles": AD = "$O$24"
        Case "Aout": AD = "$Q$24"
        Case "Septembre": AD = "$Q$24"
        Case "Octobre": AD = "$Q$24"
        Case "Novembre": AD = "$Q$24"
        Case "Décembre": AD = "$Q$24"
        Case "Janvier": AD = "$Q$24"
        Case "Février": AD = "$Q$24"
        Case "Mars": AD = "$Q$24"
        Case "Avril": AD = "$Q$24"
        Case "Mai": AD = "$Q$24"
        Case "Juin": AD = "$Q$24"
    End Select
    If Target.Address = AD Then
        Sheets("Stats annuelles").Range("$O$24") = Target.Value
        Sheets("Aout").Range("$Q$24") = Target.Value
        Sheets("Septembre").Range("$Q$24") = Target.Value
        Sheets("Octobre").Range("$Q$24") = Target.Value
        Sheets("Novembre").Range("$Q$24") = Target.Value
        Sheets("Décembre").Range("$Q$24") = Target.Value
        Sheets("Janvier").Range("$Q$24") = Target.Value
        Sheets("Février").Range("$Q$24") = Target.Value
        Sheets("Mars").Range("$Q$24") = Target.Value
        Sheets("Avril").Range("$Q$24") = Target.Value
        Sheets("Mai").Range("$Q$24") = Target.Value
        Sheets("Juin").Range("$Q$24") = Target.Value
    Select Case Sh.Name
        Case "Aout": AD = "$P$5"
        Case "Septembre": AD = "$P$5"
        Case "Octobre": AD = "$P$5"
        Case "Novembre": AD = "$P$5"
        Case "Décembre": AD = "$P$5"
        Case "Janvier": AD = "$P$5"
        Case "Février": AD = "$P$5"
        Case "Mars": AD = "$P$5"
        Case "Avril": AD = "$P$5"
        Case "Mai": AD = "$P$5"
        Case "Juin": AD = "$P$5"
    End Select
        Sheets("Aout").Range("$P$5") = Target.Value
        Sheets("Septembre").Range("$P$5") = Target.Value
        Sheets("Octobre").Range("$P$5") = Target.Value
        Sheets("Novembre").Range("$P$5") = Target.Value
        Sheets("Décembre").Range("$P$5") = Target.Value
        Sheets("Janvier").Range("$P$5") = Target.Value
        Sheets("Février").Range("$P$5") = Target.Value
        Sheets("Mars").Range("$P$5") = Target.Value
        Sheets("Avril").Range("$P$5") = Target.Value
        Sheets("Mai").Range("$P$5") = Target.Value
        Sheets("Juin").Range("$P$5") = Target.Value
    Select Case Sh.Name
        Case "Stats annuelles": AD = "$D$28"
        Case "Données": AD = "$C$9"
    End Select
        Sheets("Stats annuelles").Range("$D$28") = Target.Value
        Sheets("Données").Range("$C$9") = Target.Value
Les codes feuilles ont été modifiés?
Je te propose de remplacer dans toutes les feuilles mois Janvier, Février, ...
Le code actuel par celui-ci:
J'ai modifié les lignes suivantes
If Not Intersect(Target, [P5]) Is Nothing Then
code...
end if
    If [P5] = "Afficher tous les onglets" Then
    Sheets("Aout").Visible = True
    Sheets("Septembre").Visible = True
    Sheets("Octobre").Visible = True
    Sheets("Novembre").Visible = True
    Sheets("Décembre").Visible = True
    Sheets("Janvier").Visible = True
    Sheets("Février").Visible = True
    Sheets("Mars").Visible = True
    Sheets("Avril").Visible = True
    Sheets("Mai").Visible = True
    Sheets("Juin").Visible = True
    Sheets("(Old) Octobre").Visible = True
    If [P5] = "Afficher Aout" Then
    Sheets("Septembre").Visible = False
    Sheets("Octobre").Visible = False
    Sheets("Novembre").Visible = False
    Sheets("Décembre").Visible = False
    Sheets("Janvier").Visible = False
    Sheets("Février").Visible = False
    Sheets("Mars").Visible = False
    Sheets("Avril").Visible = False
    Sheets("Mai").Visible = False
    Sheets("Juin").Visible = False
    Sheets("(Old) Octobre").Visible = False
    If [P5] = "Afficher Septembre" Then
    If [P5] = "Afficher Octobre" Then
    If [P5] = "Afficher Novembre" Then
    Sheets("Aout").Visible = False
    If [P5] = "Afficher Décembre" Then
    If [P5] = "Afficher Janvier" Then
    If [P5] = "Afficher Février" Then
    If [P5] = "Afficher Mars" Then
    If [P5] = "Afficher Avril" Then
    If [P5] = "Afficher Mai" Then
    If [P5] = "Afficher Juin" Then
Pas souvenir de modifications, non, merci ton code marche très bien
C'est le code que j'ai donné en haut que j'ai modifié et je n'arrive pas à retomber sur mes pattes
La macro sert à avoir la même valeur dans toutes les cellules P5, j'ai du mal effacer une partie d'un code
En P5 tu as ce qu'on appelle une liste de validation (déroulante) qui te permet de faire un choix dans la liste. Il faut donc déclencher la macro seulement sur le changement de cette cellule et non toutes les cellules de la feuille.
C'est pourquoi j'ai modifié le début du code.
Voici ton fichier avec les modifications faites. https://www.cjoint.com/c/GAij7yOv3Ar
Sur l'onglet Contrainte, tu avais aussi une erreur. C'était le même code que dans les feuilles mois. J'ai fait la modif pour I5 et non P5
Bonne continuation.
Merci pour ton aide
Dans ton fichier l'automatisation de l'onglet P5 ne se fait pas
J'ai essayé avec ce code et ça marche très bien
    Dim AD As String
        Select Case Sh.Name
        End Select
Le problème c'est que j'ai d'autres codes et quand je l'ai mets tous ensembles ça ne va pas
Il est à quel endroit ce code?
This Workbook
j'ai demandé cette précision car sur le premier fichier que tu as mis en ligne un end sub perturbé le code du thisworkbook.
J'ai remis ton code en place.
Désormais, sur ce que j'ai , je n'ai pas de message d'erreur.
Ce qui est sûr c'est qu'il y a beaucoup d'interactivité entre les feuilles.
Si tu as encore contact avec la personne qui a codé le fichier, tu devrais te mettre ne rapport avec lui.
Si tu veux je mets en téléchargement le fichier.
Il n'y a pas de messages d'erreurs mais la macro n'est pas appliquée
Avec le dernier fichier que tu as posté, les cellules P5 de chaque feuille mensuelle ne sont plus liées
C'est moi qui ait codé le fichier
Mais je fais ça de façon un peu artisanale, sans grande connaissance des macros, en faisant une modification j'ai du supprimer ou ajouter une partie ce qui a fait buggé le truc
Je retrouverais où est le problème mais pour l'instant je vois pas d'où ça vient
Merci en tout cas pour le temps que tu as passé
De rien, bonne continuation.
Rechercher des sujets similaires à "bug macro"
