Incompatibilité de type
voici le code qui me retourne l'erreur?
'ligne1
       Dim lc, societe, math, phy, metodologie, dtech, elec, trigo, calphy, techno, dschema, ep, base, techniquemetier, techniquecomplementaire, prat As Single
       prat = Range("D9").Value + Range("E9").Value
       lc = Range("G7").Value * Range("G9").Value
       societe = Range("H7").Value * Range("H9").Value
       math = Range("M7").Value * Range("M9").Value
       phy = Range("N7").Value * Range("N9").Value
       metodologie = Range("O7").Value * Range("O9").Value
       dtech = Range("K7").Value * Range("K9").Value
       elec = Range("J7").Value * Range("J9").Value
       trigo = Range("I7").Value * Range("I9").Value
       calphy = Range("Q7").Value * Range("Q9").Value
       techno = Range("R7").Value * Range("R9").Value
       dschema = Range("S7").Value * Range("S9").Value
       ep = Range("T7").Value * Range("T9").Value
       If math = 0 And phy <> 0 And metodologie <> 0 Then
       base = Round((math + phy + metodologie) / 3, 1)
       ElseIf math <> 0 And phy = 0 And metodologie <> 0 Then
       ElseIf math <> 0 And phy <> 0 And metodologie = 0 Then
       base = Round((math + phy + metodologie) / 4, 1)
       ElseIf math = 0 And phy = 0 And metodologie <> 0 Then
       base = Round(math + phy + metodologie, 1)
       ElseIf math <> 0 And phy = 0 And metodologie = 0 Then
       base = Round((math + phy + metodologie) / 2, 1)
       ElseIf math = 0 And phy <> 0 And metodologie = 0 Then
       ElseIf math = 0 And phy = 0 And metodologie = 0 Then
       base = 0
       base = Round((math + phy + metodologie) / 5, 1)
Sans grande conviction.
Tu préciseras la ligne qui pose problème .
Dim prat As Double, lc As Double, societe As Double, math As Double, _
    phy As Double, metodologie As Double, dtech As Double, elec As Double, _
    trigo As Double, calphy As Double, techno As Double, dschema As Double, _
    ep As Double, base As Double
    prat = [D9] + [E9]
    lc = [G7] * [G9]
    societe = [H7] * [H9]
    math = [M7] * [M9]
    phy = [N7] * [N9]
    metodologie = [O7] * [O9]
    dtech = [K7] * [K9]
    elec = [J7] * [J9]
    trigo = [I7] * [I9]
    calphy = [Q7] * [Q9]
    techno = [R7] * [R9]
    dschema = [S7] * [S9]
    ep = [T7] * [T9]
    Select Case True
        Case math = 0 And phy <> 0 And metodologie <> 0
            base = Round((phy + metodologie) / 3, 1)
        Case math <> 0 And phy = 0 And metodologie <> 0
            base = Round((math + metodologie) / 3, 1)
        Case math <> 0 And phy <> 0 And metodologie = 0
            base = Round((math + phy) / 4, 1)
        Case math = 0 And phy = 0 And metodologie <> 0
            base = Round(metodologie, 1)
        Case math <> 0 And phy = 0 And metodologie = 0
            base = Round(math / 2, 1)
        Case math = 0 And phy <> 0 And metodologie = 0
            base = Round(phy / 2, 1)
        Case math = 0 And phy = 0 And metodologie = 0
            base = 0
        Case Else
    End Select
merci, je vais essayer
c'est la première ligne qui passe pas et je suppose les autres aussi
prat = [D9] + [E9]
    lc = [G7] * [G9]
    math = [M7] * [M9]
    phy = [N7] * [N9]
    dtech = [K7] * [K9]
    elec = [J7] * [J9]
    trigo = [I7] * [I9]
    ep = [T7] * [T9]
Que contiennent les cellules D9 et E9 ?
j'ai trouvé.
en fait je voulais calculer avec des formules déjà existantes dans ces cellules. j'ai enlever ces formules et maintenant ça marche.
merci beaucoup.
Rechercher des sujets similaires à "incompatibilite type"
