Problème colonne
Mon problème c'est que le programme à une plage de colonne et lorsque que rentre un deux 21 dans la colonne c6 et c7 par exemple j'ai bien le message, la c normal mais dès que je remet un 21 en d6 j'ai le message et la c pas ce que je veux
Voilà le programme
If Intersect(Target, Range("C6:NC11")) Is Nothing Then Exit Sub
Dim macolonne As Range
Set macolonne = Range(Cells(6, Target.Column), Cells(11, Target.Column))
If Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "21nd") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "21") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "10") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "10nd") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "33") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "DE") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "Rsec") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "GTA") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "SST") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "FP") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "35") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "507i0") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "AKPS") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "AKSC") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "CGCD") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "41") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "22") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "51") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "S2") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "S4") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "S9") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "8G") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "8F") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "L4") = 2 Or _
Application.WorksheetFunction.CountIf(macolonne, "21") + Application.WorksheetFunction.CountIf(macolonne, "R Sec") = 2 Then
UserForm2.Show
Tu ne peux pas mettre un petit fichier d'exemple avec test données ? Parce que je ne comprend pas tes explications et ne vois pas ce qui bloque.
Je pense comprendre ce que tu veux faire. Je pense que le problème vient de cette ligne :
Car il suffit que tu rentres 21 dans une seule cellule de ta plage pour que le résultat soit vrai, si tu veux vraiment afficher le Userform si tu as 21 dans deux cellules de la plage, il faut que le résultat soit =4.
Je verrai plus le code comme ça :
    Dim Tbl
    Dim I As Integer
    Dim OK As Boolean
    Tbl = Array("21nd", "10", "10nd", "22", "33", "35", "41", "51", "DE", "Rsec", "GTA", "SST", _
                "FP", "507i0", "AKPS", "AKSC", "CGCD", "S2", "S4", "S9", "8G", "8F", "L4", "R Sec")
    If Application.CountIf(macolonne, "21") = 2 Then OK = True
    For I = 0 To UBound(Tbl) - 1
        If Application.CountIf(macolonne, "21") + Application.CountIf(macolonne, Tbl(I)) = 2 Then
            OK = True
            Exit For
    Next I
    If OK = True Then UserForm2.Show
Rechercher des sujets similaires à "probleme colonne"
