c'est une bonne piste merci icemake
dans le fichier de richi2casa dans this workbook il y a
Private Sub Workbook_Open()
GetSheets
VisibleFalse
Showme
et dans l'userform
Private Trial As Long
Private Sub cmdCheck_Click()
'Declare the variables
Dim AddData As Range, Current As Range
Dim user As Variant, Code As Variant
Dim PName As Variant, AName As Variant
Dim ws As Worksheet, ws2 As Worksheet, ws3 As Worksheet
Dim result As Integer
Dim TitleStr As String
Dim msg As VbMsgBoxResult
'Variables
user = Me.txtUser.Value
Code = Me.txtPass.Value
TitleStr = "Password check"
result = 0
Set Current = Sheet2.Range("O8")
'Error handler
On Error GoTo errHandler:
'Destination location for login storage
Set AddData = Sheet2.Cells(Rows.Count, 2).End(xlUp).Offset(1, 0)
'Check the login and passcode for the administrator
If user <> "" And Code <> "" Then
For Each AName In Sheet2.Range("T8:T108")
'If AName = Code Then 'Use this for passcode text
If AName = CLng(Code) And AName.Offset(0, -1) = user Then ' Use this for passcode numbers only
MsgBox "Welcome Back: – " & user & " " & Code
'record user login
AddData.Value = user
AddData.Offset(0, 1).Value = Now
'Add usernmae to the worksheet
Current.Value = user
'Change variable if the condition is meet
result = 1
'Unload the form
Sheet2.Visible = True
Sheet2.Select
Unload Me
'Show the navigation form
'frmNavigation.Show
Exit Sub
Next AName
'Check user login with loop
For Each PName In Sheet2.Range("H8:H108")
'If PName = Code Then 'Use this for passcode text
If PName = CLng(Code) And PName.Offset(0, -1) = user Then ' Use this for passcode numbers only
'record user login
'unhide worksheet for user
If PName.Offset(0, 1) <> "" Then
Set ws = Worksheets(PName.Offset(0, 1).Value)
ws.Visible = True
If PName.Offset(0, 2) <> "" Then
Set ws2 = Worksheets(PName.Offset(0, 2).Value)
ws2.Visible = True
If PName.Offset(0, 3) <> "" Then
Set ws3 = Worksheets(PName.Offset(0, 3).Value)
ws3.Visible = True
'show sheet tab if hidden
ActiveWindow.DisplayWorkbookTabs = True
result = 1
'Unload the form
Unload Me
'frmNavigation.Show
Exit Sub
Next PName
'Check to see if an error occurred
If result = 0 Then
'Increment error variable
Trial = Trial + 1
'Less then 3 error message
If Trial < 3 Then msg = MsgBox("Wrong password, please try again", vbExclamation + vbOKOnly, TitleStr)
Me.txtUser.SetFocus
'Last chance and close the workbook
If Trial = 3 Then
msg = MsgBox("Wrong password, the form will close…", vbCritical + vbOKOnly, TitleStr)
ActiveWorkbook.Close False
Exit Sub
'Error block
errHandler:
MsgBox "An Error has Occurred " & vbCrLf & "The error number is: " _
& Err.Number & vbCrLf & Err.Description & vbCrLf & _
"Please notify the administrator"
Private Sub UserForm_QueryClose _
(Cancel As Integer, CloseMode As Integer)
' Prevents use of the Close button
If CloseMode = vbFormControlMenu Then
MsgBox "Clicking the Close button does not work."
Cancel = True
j'ai trouvé ça pour lancé un userform a partir de son nom dans une cellule
Sub TEST()
'Cell A1 of Sheet1 contains the name of the UserForm
X = ActiveWorkbook.Sheets("Feuil1").Cells(1, 1).Value
VBA.UserForms.Add(X).Show
du coup ce qu'il me manque dans un premier temps c'est lister automatiquement les noms des userform dans une colonne
puis adapter ce code sub TEST au code de richi2casa
problème je suis pas un grand spécialiste des macro
je joint le fichier avec les tableaux supplémentaires pour les userform
le code de richi2casa est trop compliqué pour mon niveau
je pense que le fichier final pourra être utile pour beaucoup
