Je voulais le mettre mais je ne voulais pas divulguer certaines info, je vais donc le modifier et je poste ça de suite!
With Me.ComboBox1
.AddItem "Opération"
Range("A8") = ComboBox1.Value
UserForm2.Show
With Me.ComboBox2
.AddItem "ABC000-001"
.AddItem "ABC000-002"
.AddItem "ABC000-003"
.AddItem "ABC000-004"
Range("B8") = ComboBox2.Value
UserForm3.Show
With Me.ComboBox3
.AddItem "x"
.AddItem "x"
.AddItem "x"
.AddItem "x"
.AddItem "x"
Range("C8") = ComboBox3.Value
UserForm4.Show
With Me.ComboBox4
.AddItem "Alpha"
.AddItem "Beta"
.AddItem "Gamma"
.AddItem ""
.AddItem ""
.AddItem ""
.AddItem ""
.AddItem ""
.AddItem ""
.AddItem ""
.AddItem ""
.AddItem ""
.AddItem ""
.AddItem ""
Range("J8") = ComboBox4.Value
CODE :
Sub Ellipse_Clic()
Dim var1 As Integer
While var1 < 1
Rows("8:8").Select
Selection.Insert Shift:=xlDown, CopyOrigin:=xlFormatFromLeftOrAbove
var1 = var1 + 1
Wend
UserForm1.Show
Sheets("Feuil1").Select
ActiveSheet.ListObjects("Tableau1").Range.AutoFilter Field:=2, Criteria1:=Range("J8")
ActiveSheet.ListObjects("Tableau1").Range.AutoFilter Field:=5, Criteria1:=Range("B8")
Range("") 'Mon pb est à ce niveau là
Selection.Copy
Sheets("Feuil2").Select
Range("").Select 'Et là aussi !
ActiveSheet.Paste
VOILA VOILA
