bonjour d3d9x
on s'est croisé quand je mettai le classeur fonctionnel, mais ton code me retourne l'erreur 70 a Me.cboTVA.AddItem tva(nbTVA)
on en revient au même point
voici le code complet attention très long mais amputé
Dim Total As Currency, T1 As Currency, T2 As Currency ', MHT As Currency
Dim Li As Long, Lx As Long
Dim i As Long, Tblo(1 To 12)
'====================================test co-viles intégré
Private Sub cboCP_Click()
Dim Choix$, Cell As Variant
Choix = Me.cboCP.Value
For Each Cell In Selection
If Cell.Text = Choix Then Me.lstVille.AddItem Cell.Offset(0, 1).Value
Next Cell
[A1].Select
Sub Init1()
Dim NoDept As New Collection
Dim A()
Dim i%, J%, NoValeur%
Dim Swap1$, Swap2$
'=======================fin test cp-villes====================================
Private Sub ajout_Click()
Dim MontantHt As Double, MontantTva As Double, MontantTc As Double, MontantRemise As Double, L As Long
'=======================code tva=================================
If Me.cboTVA.Value = "0,10" Then
.ListItems(L).ListSubItems.Add , , "1"
.ListItems(L).ListSubItems.Add , , ""
If Me.cboTVA.Value = "0,20" Then
.ListItems(L).ListSubItems.Add , , "2"
.ListItems(L).ListSubItems.Add , , Format(MontantTva, "0.00")
Private Sub lstArticle_Click()
txtArticle = "": Txtunite = "": Txt_qté_vente = "": TextBox2 = "": TextBox4 = "": txtPU = ""
Usf_articles.Show
Private Sub nomfeuil_Change()
nomfeuil.ShowDropButtonWhen = 0
Private Sub quit_Click()
Unload Me
Private Sub UserForm_Activate()
Dim tva As Variant
Dim nbTVA As Integer
tva = Array("0,10", "0,20")
For nbTVA = 0 To 1
Next nbTVA
'Effacer
With ListView1
With .ColumnHeaders 'Mise en page des en-têtes
.Clear
.Add , , "n°", 40
.Add , , "tranche", 50
'.Add , , "texte", 20
.Add , , "Nomination de l'article", 200
.Add , , "Unité", 40
.Add , , "Qté_vente", 40
.Add , , "PuHt", 60
.Add , , "obtva10", 60
.Add , , "obtva20", 60
.Add , , "tva10", 60
.Add , , "tva20,6", 60
.Add , , "Remise", 60
.Add , , "TotalHt", 60
.Add , , "TotalTtc", 60
.View = 3 ' type Report
.Gridlines = True ' affichage de lignes
.FullRowSelect = True ' sélection complète de la ligne
.HideColumnHeaders = False ' afficher les en-têtes de colonnes
.LabelEdit = 1 ' ne pas autoriser la saisie
.BackColor = RGB(255, 255, 255)
.ForeColor = RGB(0, 0, 0)
.Font.Size = 11
.FlatScrollBar = False
Me.obTranche = True
Me.obCommentaire = False
TextBox2.SetFocus
'Me.modif.Visible = False
TxAdCh.Visible = False
'ouverture.Show
CB_OK.Visible = False
Lbcp.Visible = False
Txadresse.Visible = False
LBville.Visible = False
cboCP.Visible = False
LBadresse.Visible = False
lstVille.Visible = False
txtclient.Text = Range("J4").Value
Lbdate.Caption = Sheets("Facture").Range("R1")
Lb_nomfeuil.Caption = Sheets("Facture").Range("D1")
Lbnfeuil.Caption = Lb_nomfeuil.Caption & " " & "N°"
comme cela on peu voir ou est utiliser le cboTVA
edit Minanse pas vu ta réponse et comment y utiliser cette boucle for
