Private Sub CheckBox1_Cick()
Select Case CheckBox.Value
Case True: listbox1.AddItem "HW error:"
Case False: Exit Sub
End Select
Private Sub CheckBox2_Click()
Case True: listbox1.AddItem "Power button"
End Select
Private Sub CheckBox3_Click()
Case True: listbox1.AddItem "startup"
End Select
Private Sub CheckBox4_Click()
Case True: listbox1.AddItem "RestartApplication"
End Select
Private Sub CheckBox5_Click()
Case True: listbox1.AddItem "SHUTDOWN"
End Select
Private Sub CheckBox6_Click()
Case True: listbox1.AddItem "CRASH"
End Select
Call copie_logs 'lance la macro copie_logs
Private Sub TextBox1_Change()
If TextBox1.Value <> "" Then listbox1.AddItem TextBox1
Private Sub TextBox2_Change()
If TextBox2.Value <> "" Then listbox1.AddItem TextBox2
Private Sub TextBox3_Change()
If TextBox3.Value <> "" Then listbox1.AddItem TextBox3
Private Sub UserForm_Click()
je peux cliquer sur la premiere case mais pas sur un autre il me jette erreur d'execution '424' objet requis
est ce que je dois initialiser la listbox par hasard ?
