Macro
Bonjour à tous, je sollicite votre aide
j'ai un message d'erreur (erreur de compilation, variable non définie)
sur le texte en rouge (mail =)
Dim lig As Integer, cel As Range, tot
Private Sub CmbRech_Change()
With Feuil2.Range("a2:a65536")
Set cel = .Find(Me.CmbRech, , xlValues, xlWhole)
If Not cel Is Nothing Then
Me.TextBox2 = cel.Offset(0, 0) 'Nom
Me.TextBox1 = Format(cel.Offset(0, 5), "dd.mm.yyyy") 'Date de paiement
Me.TextBox3 = cel.Offset(0, 1) 'Adresse mail
Me.ComboBox1 = cel.Offset(0, 3) 'N° de parking
Me.ComboBox2 = cel.Offset(0, 4) 'Mode de paiement
Me.TextBox4 = Replace(Me.TextBox4, ",", ".") 'Montant HT
Me.TextBox4 = Format(cel.Offset(0, 6), "0.00")
Feuil1.Range("i14") = cel.Offset(0, 6)
Feuil1.Range("i16") = cel.Offset(0, 7)
Private Sub CmdModif_Click()
cel.Offset(0, 0) = Me.TextBox2 'Nom
cel.Offset(0, 1) = Me.TextBox3 'Adresse mail
cel.Offset(0, 2) = Feuil1.Range("e3") 'Date d'enregistrement
cel.Offset(0, 3) = Me.ComboBox1 'N° de parking
cel.Offset(0, 4) = Me.ComboBox2 'Mode de paiement
cel.Offset(0, 5) = Me.TextBox1 'Date paiement
cel.Offset(0, 6) = Me.TextBox4 'Montant HT
cel.Offset(0, 6) = Format(Me.TextBox4, "# ##0.00\ €")
cel.Offset(0, 7) = cel.Offset(0, 6) * (Feuil1.Range("i15").Value + 1)
cel.Offset(0, 7) = Format(cel.Offset(0, 7), "# ##0.00\ €")
Feuil1.Range("f4") = Me.TextBox1
Feuil1.Range("c10") = Me.TextBox3
Feuil1.Range("f12") = Me.ComboBox1
Feuil1.Range("f14") = Me.ComboBox2
Private Sub CmdQuitter_Click()
Unload Me
Private Sub CmdValider_Click()
With Feuil1
.Range("c3") = .Range("c3") + 1
.Range("e3") = Date
.Range("c8") = Me.TextBox2
If Me.TextBox3 Like "*@*.*" Then Feuil1.Range("c10") = Me.TextBox3
.Range("f12") = Me.ComboBox2
.Range("f14") = Me.ComboBox1
.Range("i14") = Format(Me.TextBox4, "# ##0.00\ €")
.Range("i16") = Me.TextBox4 * (.Range("i15").Value + 1)
.Range("i16") = Format(.Range("i16"), "# ##0.00\ €")
With Feuil2
lig = .Range("a655236").End(xlUp).Row + 1
.Cells(lig, 1) = Me.TextBox2 'Nom
.Cells(lig, 2) = Me.TextBox3 'Adresse mail
.Cells(lig, 3) = Feuil1.Range("e3") 'Date d'enregistrement
.Cells(lig, 4) = Me.ComboBox1 'N° de parking
.Cells(lig, 5) = Me.ComboBox2 'Mode de paiement
.Cells(lig, 6) = Me.TextBox1 'Date paiement
.Cells(lig, 7) = Format(Me.TextBox4, "# ##0.00\ €") 'Montant HT
.Cells(lig, 8) = Format(Feuil1.Range("i16"), "# ##0.00\ €") 'Montant TTC
.Range("A:H").Columns.AutoFit
Call EnvoisMail
Private Sub TextBox1_AfterUpdate()
Me.TextBox1 = Format(Me.TextBox1, "dd.mm.yyyy")
Private Sub TextBox3_AfterUpdate()
Me.TextBox3 = Me.TextBox3
MsgBox "Ce n'est pas une adresse mail valide", , "PARKING"
Me.TextBox3 = ""
Private Sub UserForm_Activate()
Me.CmbRech = ""
Dim x As Long, j As Integer
With Feuil2
For j = 2 To .Range("A65536").End(xlUp).Row
Me.CmbRech = .Range("A" & j)
If Me.CmbRech.ListIndex = -1 Then CmbRech.AddItem .Range("A" & j)
Next j
With Me.ComboBox2
.AddItem "Cartes Bancaires"
.AddItem "Chèques"
.AddItem "Espèces"
With Me.ComboBox1
For x = 1 To 8
.AddItem "Parking " & x
Next x
Private Sub EnvoisMail()
Dim OutlookApp As Object
Dim outlookMail As Object
Set OutlookApp = CreateObject("Outlook.Application")
Set Mail = OutlookApp.CreateItem(0)
CurFile = ThisWorkbook.Path & "\" & Range("C3").Value & "_" & Range("C8").Value & ".Pdf"
ActiveSheet.ExportAsFixedFormat Type:=xlTypePDF, Filename:=CurFile, _
Quality:=xlQualityStandard, IncludeDocProperties:=False, IgnorePrintAreas:=False, _
OpenAfterPublish:=False
With Mail
.SentOnBehalfOfName = "ADRESSE@EMAIL"
.To = ActiveSheet.Range("C10").Text
.Subject = "Duplicata De Reçu "
.Body = olFormatHTML
.HTMLBody = "<br><br>" & GetBoiler("CHEMIN DU FICHIER SIGATURE HTM")
.Attachments.Add CurFile
.Send
ActiveWorkbook.Save
If Workbooks.Count = 1 Then
Application.Quit
Else: ActiveWorkbook.Close
Function GetBoiler(ByVal sFile As String) As String
Dim fso As Object
Dim ts As Object
Set fso = CreateObject("Scripting.FileSystemObject")
Set ts = fso.GetFile(sFile).OpenAsTextStream(1, -2)
GetBoiler = ts.readall
ts.Close
End Function
End Function
comme l'indique le message d'erreur, tu n'as pas défini la variable "mail".
Remplace outlookmail par mail dans l'instruction dim outlookmail dans ton code.
Merci pour ton aide mais du coup j'ai un autre message d'erreur (erreur de compilation, variable non définie)
Dim Mail As Object
bonjour,
ajoute une instruction
dim curfile à la suite des autres instructions dim
nickel un grand merci à toi ça marche super
