Envoyer par mail en PDF cellule selectionner
Bonjour a tous
je revient vers vous car je cherche une macro pour envoyer une plage de cellule (
Range("A1:AH93").Selectde la feuille active par mail en PDF sur une seul page (ben oui pourquoi faire simple )
et je n'y arrive pas.
Merci de votre aide.
re bonjour
bon j'ai avancer un peu
la première parti du code fonctionne c'est pas beau mais ça fonctionne
par contre je n'arrive pas a l'envoyer .
Sub generer_pdf()
Dim nompdf As String
Range("A1:AH98").Select
Application.PrintCommunication = False
With ActiveSheet.PageSetup
.PrintTitleRows = ""
.PrintTitleColumns = ""
Application.PrintCommunication = True
ActiveSheet.PageSetup.PrintArea = "$A$1:$AH$93"
.LeftHeader = ""
.CenterHeader = ""
.RightHeader = ""
.LeftFooter = ""
.CenterFooter = ""
.RightFooter = ""
.LeftMargin = Application.InchesToPoints(0.7)
.RightMargin = Application.InchesToPoints(0.7)
.TopMargin = Application.InchesToPoints(0.75)
.BottomMargin = Application.InchesToPoints(0.75)
.HeaderMargin = Application.InchesToPoints(0.3)
.FooterMargin = Application.InchesToPoints(0.3)
.PrintHeadings = False
.PrintGridlines = False
.PrintComments = xlPrintNoComments
.PrintQuality = 600
.CenterHorizontally = False
.CenterVertically = False
.Orientation = xlLandscape
.Draft = False
.PaperSize = xlPaperA4
.FirstPageNumber = xlAutomatic
.Order = xlDownThenOver
.BlackAndWhite = False
.Zoom = False
.FitToPagesWide = 1
.FitToPagesTall = 1
.PrintErrors = xlPrintErrorsDisplayed
.OddAndEvenPagesHeaderFooter = False
.DifferentFirstPageHeaderFooter = False
.ScaleWithDocHeaderFooter = True
.AlignMarginsHeaderFooter = True
.EvenPage.LeftHeader.Text = ""
.EvenPage.CenterHeader.Text = ""
.EvenPage.RightHeader.Text = ""
.EvenPage.LeftFooter.Text = ""
.EvenPage.CenterFooter.Text = ""
.EvenPage.RightFooter.Text = ""
.FirstPage.LeftHeader.Text = ""
.FirstPage.CenterHeader.Text = ""
.FirstPage.RightHeader.Text = ""
.FirstPage.LeftFooter.Text = ""
.FirstPage.CenterFooter.Text = ""
.FirstPage.RightFooter.Text = ""
nompdf = Environ("Temp") & "\" & ActiveSheet.Name
ActiveSheet.ExportAsFixedFormat Type:=xlTypePDF, Filename:=nompdf & ".pdf", Quality:=xlQualityStandard, IncludeDocProperties:=True, IgnorePrintAreas:=False, OpenAfterPublish:=True
On Error GoTo erreur
Exit Sub
erreur:
MsgBox "Erreur : " & Err.Number & vbLf & Err.Description
